Does this seem right?
Old Nov 20, 2015 | 10:54 AM
wotan's Avatar
wotan
1977 F250. 460 w/ a C6 transmission and 4:10 rear end. 33" tires. I seem to be running ~3200rpms at 50mph. Doesn't have a lot left in it at that point. Does this seem right?
Old Nov 20, 2015 | 11:23 AM
DirtyLarry's Avatar
DirtyLarry
I just put it into a rpm calculator and 4.10's with 33's and a 1:1 ratio should be about 2100 rpm at 55.
But with the c6's second gear ratio being 1.55 I believe, if I put that into the calculator at 55 with the same specs as before it comes out to about 3500. So maybe you aren't shifting out of second?
Maybe the rear end was geared down but according to the calculator it would have to be like a 6.2 ratio or something.
Here's the calculator FYI
http://www.crawlpedia.com/rpm_gear_calculator.htm
Old Nov 20, 2015 | 11:28 AM
wotan's Avatar
wotan
Thanks for that. That's sort of what I was thinking. I wonder how I can double-check the transmission? It's hard to hear or feel it shifting but maybe I can see it on the tach..... I also feel like maybe my diff is stuck in low.... It's a complete ******* to try and shift.
Old Nov 20, 2015 | 02:30 PM
jas88's Avatar
jas88
I think you mean your transfer case is stuck in low?
Old Nov 20, 2015 | 02:42 PM
wotan's Avatar
wotan
Yes, you are correct. Goofed on that!
Old Nov 20, 2015 | 07:11 PM
DirtyLarry's Avatar
DirtyLarry
Well gears tips multiply the torque so you should multiply the ratio to figure it out. If you have a 3:1 first gear with a 2:1 transfer case the you'd have the equivalent of a 6:1 gear ratio. So if you were in third and the transfer case was in low figure your transfer case low gear ratio and then use that in the trans gear ratio spot in the calculator. That would tell you what rpm having your t case in low would make you turn in any given situation
Old Nov 20, 2015 | 08:52 PM
J ballan's Avatar
J ballan
I seriously doubt you could hit 50mph in low range. If you are running over sized tires you will actually be going faster than what your speedo is reading. So between that and the fact that the C6 transmission does not have a torque converter lock (there is always some slippage) I would say that is perfectly normal.
Edit. Just re read it and that does seem high. I would make sure it's shifting through all the gears. Good luck.
Old Nov 20, 2015 | 08:55 PM
J ballan's Avatar
J ballan
Also if you want to check your tranny just floor it and count the times it shifts. Should have a 1-2 shift then a 2-3 shift.
Old Nov 20, 2015 | 09:55 PM
Blue and White's Avatar
Blue and White
3200 RPM should be in the 70's not 50's with your combo. Agree something is not right.
Old Nov 21, 2015 | 07:29 AM
Steven@nd's Avatar
Steven@nd
FWIW my 390 C6 with 3.50 rear gears is about 2800 rpm at 65 mph with 235/75r15 tires. 3000 rpm is right around 70 mph.
Old Nov 22, 2015 | 04:21 AM
77 1/2 F250's Avatar
77 1/2 F250
Been a few years since I had my 77 on the road (400/ C6/ 205/4.10) with LT305/70R16 (~33-34") but as I recall 3200 rpms put me pretty close to 75mph, verified with a GPS.
I'll bet it isn't shifting into 3rd. Easiest way to verify is to start out in 1st and shift it manually.
Robert
Dr.feelgood
Modular V10 (6.8l)
Feb 11, 2009 11:48 PM
Sandidande
Apr 16, 2007 07:25 AM
BlueDolphin
47
Aug 7, 2005 11:47 PM
Semperfi45601
1978 - 1996 Big Bronco
Apr 21, 2004 11:42 AM
ChadR93
Nov 29, 2001 01:50 PM
