Hubs in lock position
Old Nov 18, 2015 | 02:40 PM
AppocAlexx's Avatar
AppocAlexx
Never really looking at the hubs on my ex I looked today and they have been the lock position since I've owned it and no telling how long before then. I've had it for about 8 months now. Is this a bad thing? I was looking at replacing them with manual hubs and looking into the mm 449ss.
Old Nov 18, 2015 | 02:42 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Not necessarily a bad thing, but it'd be a good idea to see if they flip back to open and maybe grease them up a bit. Wouldn't hurt to check the axle shaft u-joints as well and see if they're worn out.
LivingLarge's Avatar
LivingLarge
You will be fine, lots of guys in Alaska leave them locked in all winter.
Old Nov 18, 2015 | 02:46 PM
harley4jcs's Avatar
harley4jcs
I like my MM 449SS. You might pick up a solid 1MPG when you flip'um.
Old Nov 18, 2015 | 03:56 PM
AppocAlexx's Avatar
AppocAlexx
Sounds good. Ill pull them apart and get them all clean and greased up. Any recommendations for grease?
Old Nov 18, 2015 | 03:58 PM
AppocAlexx's Avatar
AppocAlexx
I also do hear a good thumping sound when at full turn in the front end. I always thought it was the u-joints. If this is an issue that leaving them in lock position can make happen then they are most likely the culprit. Im looking at doing the ball joints soon and will be inspecting other things as well and will for sure look into the u-joints now for replacement just in case.
Old Nov 18, 2015 | 07:39 PM
The2003Excursion's Avatar
The2003Excursion
If you have it apart. ....
Ball joints K80026 K8607T (XRF brand....look at ebay)
Hub SP580205 Timken
Hub seal (skinny yellow one - comes with the Timken ones at least)
Axle shaft seal - Big blue/gray one - SKF 28600
Axle dust seal Ford F81Z-1S175-HCA
Front Spicer ujoints Spicer SPL55-3X
Send Andy "Snowseaker" $10 or so for a hub lube fitting
Get an axle seal install tool. Otc 6695
Watch a bunch of youtube videos
Check brakes....especially slides
Old Nov 18, 2015 | 07:56 PM
Krazee Matt
Veteran: Navy
I used the #2 write-up in the tech sticky up top to do my F'ing ball joints (read: turned into full front end rebuild). It also includes the parts list to make your own seal installer from a hardware store (sourced my parts from Home Depot for $15, plus 15 minutes turning the flange down to size with an angle grinder).
Ford Super Duty Ball Joint Replacement Procedure | Superdutypsd.com
Guzzle has some good write-ups for the stock hub maintenance and greasing as well.
http://www.guzzle7pt3.com/nblube.php
http://www.guzzle7pt3.com/allube.php
Old Nov 19, 2015 | 02:41 PM
AppocAlexx's Avatar
AppocAlexx
Sounds great thanks I have downloaded some of the PDFs from guzzlers, that guy is awesome
Old Nov 20, 2015 | 10:54 AM
AppocAlexx's Avatar
AppocAlexx
I was able to use the 4x4 this morning and it seemed to be working from what I could tell. The only thing that was weird is that when almost at full turn left and right my steering wheel would kind of jerk I guess u could say. I've driven 4wd with independent front suspension and know how that feels but never driven with a front end like this. Is this a normal thing for this set up on the Excursion/Super Duty?
Old Nov 20, 2015 | 12:27 PM
nmclella's Avatar
nmclella
That's the wheels binding up because they aren't getting enough slippage with the ground you're on - if on pavement or other very high traction surface this can be really hard on parts
gunner0828
Jun 22, 2012 03:09 PM
Wizzerd
Feb 14, 2010 08:20 PM
dell
May 28, 2007 08:29 PM
electricmaniac2
Offroad & 4x4
Nov 18, 2002 04:12 PM
George
1978 - 1996 Big Bronco
Jan 2, 2000 10:52 AM
