Removing doors
Old Nov 17, 2015 | 11:23 PM
willowbilly3's Avatar
willowbilly3
Removing doors
Pulled the doors from my 47 parts cab today, wow, what a pita. I have done a few but these were tough. Heat didn't work, pin just swelled in the hinge and refused to move. I ended up drilling 3 out of the 4 and 2 of those I had to drill from both ways (which would be impossible on the lowers if the truck was together). When I pull them from the panel, I think I'll just start right out cutting off the heads, drilling down from the top past the top section before I try to drive on out.
Old Nov 18, 2015 | 09:31 AM
HermanTheGerman's Avatar
HermanTheGerman
I had the same problem, needed to drill out 2 of 4. The two that came out can be reused. Or is it better to buy new ones?
Old Nov 18, 2015 | 09:39 AM
tacomacream's Avatar
tacomacream
Ford Parts Search - C&G Ford Parts
I would by new ones.
Old Nov 18, 2015 | 12:00 PM
willowbilly3
I have some new ones, cheap. But now I could use some longer ones, one for the mirror and the rear doors use longer ones, although the standard ones will work, just little shy of coming clear through.
I'll just mount my doors all with 1/2 inch bolts until final assembly so I can take them back off easily.
jmadsen
May 27, 2008 07:56 PM
FLUSHED UP
Jun 7, 2007 05:49 AM
captain p4
1978 - 1996 Big Bronco
Aug 15, 2006 12:58 PM
1970Custom
19
Nov 12, 2005 07:52 AM
