Thermostat Stuck Open?
Old Nov 16, 2015 | 12:03 PM
Raleigh234's Avatar
Raleigh234
I've been keeping track of this problem for a while lately, and I *think* this is the culprit. My stock temp gauge (dashboard) doesn't move. For a while, I had assumed the gauge or sensor was broken, but lately, its started to move again, and mostly towards hot. This had me thinking that my thermostat has been stuck open for a while, and it somehow closed and now won't open again. I don't have an aftermarket gauge set (yet) so I can't measure temperature accurately, but I wanted to make sure my reasoning sounded plausible.
I've also noticed I've never replaced my thermostat before, in the 7 years I've owned the truck, so that also has me leaning towards thermostat.
Old Nov 16, 2015 | 04:10 PM
Tugly's Avatar
Tugly
I'm guessing you never replaced or charged the coolant either (assuming it's not ELC). If not, you may want to....
  1. Order a thermostat housing and a thermostat.
  2. Download Gooch's coolant flush directions.
  3. Sweep the supermarket shelf of distilled water and buy 4 gallons of quality antifreeze.
  4. Perform the coolant flush and install a new thermostat.
Might I suggest you get an IR gun? They are not expensive, and knowing the temperatures of everything from coolant, to brakes, to exhaust manifolds at idle is extremely helpful with a 15-year-old diesel truck.
Old Nov 16, 2015 | 08:27 PM
ScaldedDog's Avatar
ScaldedDog
Raleigh, this is a great suggestion. I have a harbor freight one, and use it all the time.
Mark
Old Nov 16, 2015 | 09:04 PM
Zwalters's Avatar
Zwalters
I'm pretty sure I have a similar issues as truck will not idle up to op temp. I too plan on doing a therm job and maybe a couple hoses and water pump..maybe on the water pump for certain.
Old Nov 17, 2015 | 06:43 AM
Tugly's Avatar
Tugly
At idle, it only really warms up during the "jet" phase. This is when the idle revs up and the Exhaust Back Pressure Valve closes to make a jet sound out the exhaust. If you are at low idle, the engine never really gets all that warm. This doesn't mean you don't have an open thermostat on your truck, it just means don't expect a fire breathing dragon to leap out of your heater until you're on the road.
Saying that - I know from experience that a "full heat" reading on the temperature gauge is maybe just enough to get past the 140-degree mark on the Engine Oil Temperature.
A/Ox4
118
Jun 25, 2017 10:11 PM
Eddie C
Feb 9, 2016 07:00 PM
IT_Dude
Jan 11, 2011 08:36 AM
PeteC
Modular V10 (6.8l)
Jun 25, 2008 11:09 AM
waldreps
1983 - 2012 Ranger & B-Series
Sep 18, 2006 11:33 AM
