Modular V10 (6.8l)
Thermostat Life?
Old Jun 21, 2008 | 09:13 PM
PeteC's Avatar
PeteC
Thermostat Life?
My 99 (Bought May 98) is due for a coolant change. The thermostat is the original one. The engine temp gage shows in the normal range but I don't know that the gage is very accurate. I only have 62,000 miles on the truck.
At 10 years should I go ahead an replace the themostat?
Old Jun 22, 2008 | 12:00 AM
Monsta's Avatar
Monsta
Sit. Stay.
How much does it cost? Is your piece of mind worth that?
Old Jun 23, 2008 | 11:07 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
ALWAYS test the new thermostat! Put it in a pot of boiling water with a thermometer if you can and make sure it opens fully at boiling.
The gauge is a glorified idiot-light. It has a wide swing in temp before it even shows high.
Old Jun 23, 2008 | 12:21 PM
dkf's Avatar
dkf
You should replace the thermostat when doing a coolant flush. To do a good flush the thermostat should be removed anyway. I'd replace it.
My scangauge usually shows 188-190 degF.
Old Jun 24, 2008 | 05:30 PM
FordxFour's Avatar
FordxFour
For the "Peace of Mind" I change the T-Stat and hoses every 2 years needed or not. I also test it before installation. Glad to know I'm not the only one cooking T-Stats, the D/W thinks I've gone nuts. Been driving for 30 yrs and never had a cooling related failure on the road.
Old Jun 25, 2008 | 09:16 AM
juterbock's Avatar
juterbock
FordxFour,
When I did my hoses two weeks ago, I found that the lower hose with the 2 tees back to the oil cooler above the oil filter was a real joy to remove. I ended up removing the oil filter to get a set of pliers on the clamps. Is there a better trick, it really annoyed me since I had just done an oil change a 1000 miles previous.
Thanks
Old Jun 25, 2008 | 11:09 AM
FordxFour's Avatar
FordxFour
juterbock, not really thought of a trick for removing the clamps. I just change the oil at the same time that I'm replacing the hoses. I suppose you could use regular clamps but I don't think that it will really make the job any easier.
