1978 - 1996 Big Bronco
Great engine, poor drivetrain, poor engine, great drivetrain.
Old Nov 15, 2015 | 09:51 PM
Thunderhorn's Avatar
Thunderhorn
So, I have the 79 Bronc with my built 400 bolted to a C6 and np203 t-case. I love the 400 but I hate the C6 and the full time 4x4 203. Im looking at a donor 1978 bronco with a smogged down bone stock 351m but a solid 4speed manual and the np205 t-case. I really want my 400, and I really want the manual transmission and the part time t-case. plus it would be nice to have the stock 351 as a spare engine. Question is, can the bellhousing be changed so that i can stick either engine on either transmission? or can you only mate like-transmission engines? Ive never done a transmission swap like this before so sorry if this is obvious. I cant seem to get a clear answer on the rest of the forums either.
Old Nov 16, 2015 | 05:10 AM
gatorfor88's Avatar
gatorfor88
The 351m/400 are the same engines as far as exterior. Either one will bolt up to either tranny. I think you can even pull the flywheel off the 351m and bolt to the 400 and be a direct bolt in. It is possible the 400 uses a larger clutch/pressure plate but I am not sure.
trapperjack
41
Feb 14, 2010 11:24 PM
CLR f-150
Apr 30, 2007 12:37 PM
forcury
Oct 28, 2005 10:21 PM
Lane Dexter
19
Aug 16, 2005 10:51 AM
calazo
18
May 19, 2004 03:01 PM
