coil spring advice
84 w/ straight six 300, single shocks up front and 89 with 302, dual shocks up front
On the 84 I just want to restore stock ride height, looking at using the MOOG CC818, this is basically a ranch vehicle -never sees pavement, used for driving pasture and fence repair. Currently sitting on bump stops. Appreciate any input and experience. tires are 31x10.5x15
The 89, I would like it to sit about a 1" over stock. All the coil springs I see, say except dual shock option. Not sure is this is an issue? As mentioned it has dual shocks. I am thinking about using the MOOG CC818 also with 1" spacer, also see that MOOG has a CC822 that looks like it would achieve the same stance without the spacer. Looking for suggestions to achieve the 1" over stock. Mainly for looks. I have 32x11.5x15 on it. This one is used same as above, but spends a lot more time on the road. It has original springs and they are worn out.
Appreciate and help or suggestions you can give related to coil springs. Thank you,
