General Automotive Discussion
Coil over shocks question...
Old Jun 27, 2013 | 02:49 PM
parkland's Avatar
parkland
Not too smart with springs....
I'm putting together a go kart.
Can I use coil over shocks for the springs, or are those designed to be used in conjunction with another spring?
Hoping I can buy coil over shocks for a VW or something, and that will be all I'll need for springs.
Old Jun 27, 2013 | 03:56 PM
parkland's Avatar
parkland
I am guessing my go kart will weigh around 1200 lbs when it's 100% finished, and the VW bettles were around 1600 from what I have read.
This seems like a decent close match.
If I used coil over shocks springs from a van or truck, I suspect it would ride like a brick?!
Old Jun 28, 2013 | 12:26 AM
85e150's Avatar
85e150
At 1200 lbs, it is not a "go kart".
Coil overs. Are you thinking of:
--load leveler shocks with springs?
Monroe Load-Leveler Shocks - Shockwarehouse.com
--a shock that incorporates the spring, such as those found in the front of a Toyota Tacoma?
Bilstein shocks and struts for cars and trucks - Shockwarehouse.com
http://image.motortrend.com/f/roadte...coil-overs.jpg
A Macpherson strut set up, where the strut/shock/spring is part of the suspension structure, without upper control arms etc:
http://www.rapid-racer.com/resources...=1304442062795
Old Jun 28, 2013 | 01:53 AM
parkland's Avatar
parkland
Lets say these :
http://www.ebay.com/itm/VW-Bug-Dune-Buggy-Adjustable-Coil-Over-Shocks-Pair-/310690599221?pt=Motors_Car_Truck_Parts_Accessories&hash=item48569a5135&vxp=mtr
of course with control arms holding the axles in place...
Old Jun 28, 2013 | 02:18 PM
85e150's Avatar
85e150
They don't list the spring rate there. Don't those just supplement the stock springs when installed in a VW?
The mounts look like standard shock mounts. Not designed to carry the full weight of the vehicle.
They might work, they might not.....
Old Jul 11, 2013 | 02:56 PM
parkland's Avatar
parkland
Yes that is exactly what I don't understand
Old Jul 12, 2013 | 12:19 AM
85e150's Avatar
85e150
Serving suggestion, maybe a silly way to do it.
Put some solid bars in place of your shocks/coilovers. Check your weight distribution. 1200 total, but see what it is front to rear. You may need more support, or the same depending on what you find. Adjust for your stance and desired right height.
Something with the preload adjustment is probably what you want, and you can also use two per wheel if need be.
Maybe find some at the scrappy before you pay good money for new--then you can do some testing without breaking the bank.
The of course there are always air shocks. GM minivans had them--the Oldslowpile in particular had them....and they provided quite a bit of support, so the mounts were made to take it. Ditto older El Caminos.
Ortarheel
May 29, 2013 07:26 AM
Harfend
Dec 17, 2008 11:10 PM
kne831
Aerostar
Oct 10, 2006 12:52 AM
oldhalftons
1978 - 1996 Big Bronco
Nov 15, 2005 05:55 PM
Outlaw08
Offroad & 4x4
Mar 18, 2005 07:55 AM
