over charging issue
Old Nov 14, 2015 | 09:43 PM
86dieselnut's Avatar
86dieselnut
over charging issue
I have an 86 250 with the 6.9 diesel. I have been having issues with over charging at idle i have 13.5v and reved up its putting out 16.5v i have replaced the regular multiple times with no change and i have noticed that it gets very hot as well. I unplug the regulator and voltage drop to battery voltage. On the regulator terminals the f is connected to the alternator with a orange wire the s is a green and red wire with ign power the a is a yellow wire with battery voltage. Im not sure if I have a short anywhere and i can't find the right wiring diagram anywhere any help is appreciated. .. thanks
Old Nov 15, 2015 | 04:13 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Do you have an ammeter or just a charge light?
If there is battery voltage present at the yellow (sense) wire this is correct.
You may just have to add a ground to the mounting bolt of the regulator case.
This has resolved a full field charge problem for others before.
Old Nov 15, 2015 | 06:38 AM
Franklin2's Avatar
Franklin2
How are you checking the voltage and where? If you are using a handheld meter, what voltage reading do you get on the battery with the engine off?
Old Nov 15, 2015 | 08:54 AM
JimsRebel's Avatar
JimsRebel
Is this a G2 ALT?
Old Nov 15, 2015 | 09:13 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Not if it has a regulator on the fender and a stud mounted charge cable.... as was already said.
Old Nov 15, 2015 | 12:20 PM
86dieselnut
The truck only has an ammeter
And im checking with a mulitmeter at the right battery and the regulator connector. Engine off voltage is 13v
Old Nov 15, 2015 | 12:33 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Thats too high at rest.
You're going to boil your battery.
Add a ground wire to the regulator case and see if the voltage while running returns to normal. 14.7v max
Old Nov 15, 2015 | 05:29 PM
86dieselnut
Added a ground and it didn't solve the problem also i put my multimeter on the field wire and got 12.5 v while running and with everything off i got 10.5v on the field wire i disconnect the regulator and volts drop to 0v is it a bad regulator cause I've replaced it a few times already
at38b
Electrical Systems/Wiring
Oct 26, 2013 12:11 PM
Muddy86F150
Mar 26, 2010 07:15 PM
fisherm1
Aug 14, 2008 09:07 AM
elstx
Oct 15, 2003 06:58 PM
