chrging system trouble
Old Aug 13, 2008 | 09:43 PM
fisherm1's Avatar
fisherm1
I'm currently working on a 1974 F250 ranger with a charging issue. The truck keeps running the battery dead in the course of a day of driving. Both the alternator and voltage regulator were recently replaced, but the voltage at the battery won't go above 12.75 no matter how high the RPM's and the alternater dummy light won't turn off. I took the new alternator in to be tested and it checked out alright. I've double checked the ground on the alternator but don't know where the ground is on the VR.
Any suggestions are appreciated.
Old Aug 14, 2008 | 01:27 AM
ReAX's Avatar
ReAX
I haven't worked on an external regulator in quite a while, so I might be off. There should be a terminal marked F, this should be the field terminal and have 12volts on it and at the regulator. On my truck when this has a ground the light in the dash comes on, when it's powered properly the light sees 12v and doesn't come on.
Old Aug 14, 2008 | 09:07 AM
subford's Avatar
subford
The ground for the regulator is its frame.
Make sure that what it is bolted to is at ground or run a wire from one of the mounting bolts to the neg post of the battery or a good ground on the engine.
Put a volt meter on the battery and hold a wire from the pos post of the battery to the "F" screw on the regulator or alternator for a very short time.
If the voltage jumps up when you touch the "F" on the alternator but it does not when you touch the "F" on the regulator then you have a bad "F" wire from the regulator to the alternator.
If the voltage jumps up at both places then make sure you have battery voltage at the "A" screw on the regulator and the regulator is grounded.
Wire colors may differ in the following diagram.
ckleine
Aug 30, 2014 05:24 AM
zlusmc
May 26, 2011 12:10 AM
NavyMIDN08
29
Jan 5, 2010 10:06 PM
iacowboy
Apr 17, 2008 05:50 PM
madmader
Feb 26, 2008 05:34 PM
