F1 fuel gauge and mustang sender bench test video
Here is a quick video I made. I'm using a L7806 constant voltage reducer, and a 9 volt battery for test purpose only. I don't know how the gauge is going to react once the sender is in the tank. I'll probably do another video then. This is all I have for now.
Nice video, only comments I would have is that I would have liked to have seen the actual voltage applied to the circuit out of the L7806 and the actual resistance as read across the fuel sender. You alluded to the fact that the float rod could be bent to match the tank, I have found that it is difficult to gauge the distance that the float will be above full deflection either at the top or bottom when installed in the tank. In my 40 I read the resistance across the sender with the tank dry and then at 1 gallon intervals as I filled it just to see how linear the resistance readings were at various levels. Thanks for putting forth the effort to video document your test and sharing it with the forum.
L7806 pdf, L7806 description, L7806 datasheets, L7806 view ::: ALLDATASHEET :::
Table 6 on Page 11 is of interest - 9-25V with a max voltage of 35V and a tolerance of +/- .25V
Can't speak to the sender...but my experience with the L7806 shows them to be very stable regardless of input voltage/current...
Well, I didn't make a video, but I did experiment with the ohms of both the sender and the gauge, the sender at empty is 74.5 ohms, full is 11 ohms. The gauge, well since I couldn't get an ohm reading while electric was supplied I applied 6 volts, disconnected it and immediately the only ohm reading was 11 ohms this was with the needle at full descending to empty. So this must be where the bimetal vs variable resister gauge comes into play. I had the l7806 voltage reducer hooked to a 12v battery. It supplied a constant 6v power to the gauge. This is pretty much all I'm going to do until the fuel tank is in. Then I'll do a video with water in the fuel tank at one gallon increments.
Amish65F100
04-15-2017 09:38 PM
Sooper Camper
16
07-08-2013 11:32 AM
merten
11-03-2007 02:30 PM
keisha9
09-19-2007 07:55 AM
