Year codes
Old Nov 12, 2015 | 11:45 AM
Ruffasacob's Avatar
Ruffasacob
Year codes
What part of the VIN is the year stated?
What would the code be for 1964, 1965, 1966?
I'm looking at some trucks, and I can't go by the grills to identify them.
Thanks
Old Nov 12, 2015 | 02:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The Numerical Sequence of Assembly (the last 6 digits of the VIN), decodes to the year.
Old Nov 12, 2015 | 02:52 PM
Ruffasacob's Avatar
Ruffasacob
Thanks Bill, that's perfect.
Old Nov 12, 2015 | 03:25 PM
wanta65's Avatar
wanta65
my vin is f10dk698318
title says year is 1966.
the way i read that chart says it's a 65.
am i reading chart wrong?
Old Nov 12, 2015 | 04:31 PM
TA455HO's Avatar
TA455HO
Lead Gopher
You are reading the chart correctly. 698318 would be a 1965.
Old Nov 12, 2015 | 05:28 PM
wanta65's Avatar
wanta65
imagine that. 65 is what i wanted anyway. lol.
reckon the county clerk will change the year and vin? both are wrong.
Old Nov 12, 2015 | 05:30 PM
SuperSabre's Avatar
SuperSabre
Another bit of interesting information regarding the 1965 model year F100; that was the only year engine code "D" was used to denote the truck being equipped with the 352 2V FE V8 engine. For '66 and '67 (the only other years the 352 was used) the engine code was "Y". That should help your state vehicle bureaucrats identify the truck as a '65.
Old Nov 12, 2015 | 06:24 PM
TA455HO's Avatar
TA455HO
Lead Gopher
My 1966 Ranger had two digits transposed on the paperwork since day one in California. As I titled it here in Washington state I was able to get it corrected with a little back and forth at our Department of Motor Vehicles. Patience with the particular given bureaucratic system is usually key to getting it done. I gave them what they asked for in both pictures and pencil rubbings and followed up with a phone call to the central office in the state capital. It worked out well in the long run.
Old Nov 12, 2015 | 08:04 PM
wanta65's Avatar
wanta65
it does have the late model 65 or 66 grill. maybe that's what they went by. i'll be looking for a 65 grill. i like the squares better.
Old Nov 13, 2015 | 11:10 AM
NumberDummy
my vin is F10DK698318 / title says year is 1966. the way i read that chart says it's a 65.
No.
F10 = F100 2WD
D = 352 2V
K = Kansas City MO Assembly Plant.
698318 = 1965, assembled June 1965.
September 1965: FoMoCo replaced the 1965 grilles with 1966 grilles for use as "service part replacements."
Old Nov 14, 2015 | 04:34 AM
wanta65's Avatar
wanta65
thanks for all the good info.
did they put padded dashes in 65s?
Old Nov 14, 2015 | 02:17 PM
lauxg's Avatar
lauxg
VIN 1966 F100 ?
The more I try to understand the VIN codes the more confused I get. I recently purchased a 1966?? F100. The VIN is F10YD803686, the following numbers are 115 H F100 481 A A9 05000 172 4000 75. Can anyone tell me what all of this means? All help and replies will be greatly appreciated. In Fords I have a 1966 Ranchero, a 1966 F100, a 1972 F100, and a 1989 F350, you would think by now I could understand the codes, but..............
Last edited by lauxg; Nov 14, 2015 at 02:54 PM. Reason: I thought I was adding pictures
Old Nov 14, 2015 | 02:51 PM
lauxg's Avatar
lauxg
I have added a couple of pictures of the VIN
Old Nov 14, 2015 | 03:59 PM
NumberDummy
Originally Posted by lauxg
VIN: F10YD803686 / Warranty Plate = WB: 115 / COLOR: H / MODEL: F100 / BODY: 481 / TRANS: A / AXLE: A9 / MAX GVW LBS: 05000 / CERT NET HP: 172 / RPM: 4000 / DSO: 75.
F10 = F100 2WD
Y = 352 2V
D = Dallas TX Assembly Plant.
803686 = 1966, assembled January 1966.
115" Wheelbase.
H = Sahara Beige.
F100 2WD, 5,000 lbs. GVWR
481: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
A9 = Dana 60.2 Rear Axle / 3.54-1 / Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
75 = Phoenix AZ Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Nov 15, 2015 | 05:31 PM
lauxg's Avatar
lauxg
Thank you for this information, it is greatly appreciated.
tyedye
Feb 21, 2018 10:10 AM
fordtech08
Feb 21, 2014 05:47 PM
rcwood
Apr 19, 2012 07:42 AM
meangenejr
Jan 4, 2006 06:24 PM
high ho silver
Jan 13, 2005 02:02 PM
