NO Luck there... 4 wire,... tail light, left turn, right turn. Ground. NO POWER.
and not any one of them will handle 5 amps... much less a power Jack.
a single 12 gauge wire with a 20 amp fuse from truck battery to trailer jack .. and a single connector near jack to disconnect from truck.
I have the 7 pin connector too, so I can use that for the jack, I just did not want to mess with the 7 pin wires, to make sure I don`t screw up the brakes
And I wanted to use the 4 pin for internal LED lights ( enclosed trailer ) and I thought I can connect the jack to while I`m messing with the 4 pin, but if they don`t have enough amps, than I will only use the 4 pin for the LEDs.
I purchased my 28' TT with the electric tongue jack already on it. The PO just ran the hot lead from the tongue jack straight to the TT battery (fused of course) I like that way. I don't have to have it hooked to my truck to raise & lower it. Mine is a cheap one and water leaked into the head unit through the Bulls Eye level on the top (remove the Bulls Eye level to use the manual crank handle) I had to replace a micro switch. I now keep it covered with small bucket when it's stored to keep the rain out and keep a spare micro switch just in case.
And what about a standard enclosed trailer which does not have it` own battery like the TTs?
Just connect it somehow to the light wires or what?
3500lbs rated should be fine for a 20' long, 10k max twin axle enclosed trailer right?
That 10k tandem axle 20' enclosed trailer should have at least a small battery on it to power your brakes via the breakaway switch. It does have a breakaway switch doesn't it? That little battery should be getting fed by the 7 pin currently, so tapping jack power to it should be pretty simple. Sometimes those small batteries are tucked away, it may not be obvious but that trailer should have a complete breakaway system including battery.
Well, the Husky 4500lb electric tongue jack is here. Can't install till the trailer comes out of winter hibernation..... but gives me something to look forward to.
Finally remembered to post a pic of my Husky jack installed. Totally happy.... it lifts the back of my Excursion no problem to allow me to grab the link I need with the snap up bracket.
I've got a Bulldog 3500# that's wired to my camper battery. It works....sometimes. Sometimes it works as it should and sometimes it barely creeps. I had to hand crank it today cause it drained the battery on the camper sitting in storage. But even the hand crank was 10x better then the factory hand crank Jack that was on it.
