FICM
Old Nov 10, 2015 | 06:50 PM
18vtx00's Avatar
18vtx00
FICM
How many folks here have a had low FICM voltage and severe raw fuel/white smoke?
Old Nov 10, 2015 | 07:57 PM
78fordman's Avatar
78fordman
I have. Mine was getting down to 25v. Ran like crap and smoked.
Old Nov 11, 2015 | 02:28 AM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
What you describe is a VERY common symptom of a bad FICM. We'd be happy to help you out if that is of benefit to you. We can either work on yours or ship you one out on exchange to limit your downtime.
Hope this helps!
Old Nov 11, 2015 | 07:54 AM
18vtx00's Avatar
18vtx00
Hope this helps!
I've changed at least 100 FICMs, but never seen one smoke this badly or run the voltage quite this low without a cold no-start or P0611. It runs fine on cold start up, power seems about normal and doesn't miss...until you shut her off and then start after a warm soak. Then she misses badly and skips like crazy and will fill the yard with white smoke. Had a dead #4, so replaced that injector. I Have 48 volts during cranking but as you step on the throttle it rapidly drops to 22 volts. Thanks for the reply!
Old Nov 11, 2015 | 07:55 AM
18vtx00's Avatar
18vtx00
Mine should be here Friday, thanks!
Old Nov 13, 2015 | 07:38 PM
18vtx00's Avatar
18vtx00
FICM came in and I installed it today, no more white smoke and much better throttle response than it ever had with the stock file. I opted for the 48 Volt. Will reflash with my tuner tomorrow...hehe!
Old Nov 13, 2015 | 07:40 PM
FICMrepair.com
Former Vendor
Thanks very much for the business!! Enjoy the truck!!
meccox
Feb 12, 2013 10:25 AM
caleb6.9
Feb 14, 2010 02:42 PM
Vinford
23
Jan 29, 2009 10:44 AM
61 uni
May 18, 2007 02:47 PM
