Tekonsha P3 problem
Old Nov 10, 2015 | 11:18 AM
rogers017's Avatar
rogers017
Trailering
Tekonsha P3 problem
I just picked up my new toy hauler over last weekend and it took several minutes for the P3 to see my trailer. On the way home everything went smoothly. Taking her over to storage and the P3 kept saying no trailer attached. The output voltahe is 13.6 but the output current says at 0.0 with my foot on the pedal. Is there anyting I need to check before I chalk this one up as a defective unit and get a new one?
I also used their wiring specific harness so I could plug into the factory connection if that helps out.
Old Nov 10, 2015 | 01:28 PM
RV_Tech's Avatar
RV_Tech
Yes, I would encourage caution in blaming the controller, it almost never is. The controller is most likely alerting you to a poor connection at your seven pin. You just plugged in a new trailer, go there first. The controller is the most reliable component in that entire circuit.
Just my two cents worth,
Steve
Old Nov 10, 2015 | 01:29 PM
Chuck's First Ford's Avatar
Chuck's First Ford
check the truck connector... at the rear of the truck.. dirt/corrosion at the pins... or the pins are not pressing on the trailer pins.
Old Nov 10, 2015 | 02:59 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
If all seems OK, call Tekonsha - they are most helpful manufacturer I have ever dealt with.
Old Nov 10, 2015 | 03:07 PM
rogers017's Avatar
rogers017
Trailering
Thanks for the quick info. Yeah I was a little hesitant to say a faulty trailer brake thats why I asked. The truck is a 2002 F250 and didn't seem to ever see a trailer so I will start a the 7 pin. If its just corrosion is there anything you guys reccomend (on my tractor trailer we would just use a little sandpaper but those are pins and not blades so I dont know how well that will work)?
Old Nov 10, 2015 | 03:57 PM
Chuck's First Ford
I use wet/dry (dry) 1000 grit sandpaper.. a small piece folded in half .. to do both sides at once... like a small fingernail file...
otherwise a new 7 pin connector.
Old Nov 19, 2015 | 09:11 AM
A Rodder's Avatar
A Rodder
I generally find if the problem is at the rear (which it usually is), it's on the BACKSIDE if the 7 way where the harness hooks to plug.
Not the actual blades of the plug.
Replacement oem style plug in plugs are available at any reputable hitvh shop or online for 12/20 dollars or so.
mototrig
Nov 17, 2018 09:49 PM
ndlawrence
Jul 16, 2013 05:53 PM
FloridaStroker
All Things Towing
19
Jun 15, 2013 07:22 AM
MKRemi
6.7L Power Stroke Diesel
22
Apr 12, 2012 07:48 PM
budhead1
Apr 21, 2006 08:57 AM
