Front tank says empty, not!
Old Nov 10, 2015 | 10:23 AM
compaddict's Avatar
compaddict
Save me some searching please!
TIA,
Vince
Old Nov 10, 2015 | 10:51 AM
madpogue's Avatar
madpogue
Most likely the float has sunk. Contrary to the listings you might find, the float can be replaced separately; it just snaps onto the arm. Unfortunately I don't know of a good quality replacement. I replaced mine about a year ago, IIRC it was from Summit Racing. It appears to have sprung a leak and sunk already.
One slim possibility is that the sending unit has hit a bad spot on the variable resistor. But it's unlikely. Typically when that happens, it fails as an OPEN circuit (infinite resistance), which would appear on the gauge as pegged way past full. For it to be the sending unit, it would have to fail as a SHORT circuit (zero or very low resistance).
Old Nov 10, 2015 | 11:22 AM
compaddict's Avatar
compaddict
Thanks man! Ill run it on the front tank and see if it goes down.
Old Nov 10, 2015 | 12:00 PM
madpogue's Avatar
madpogue
Hmm, that's confusing. Isn't the gauge reading on empty on the front tank now?
Old Nov 10, 2015 | 12:15 PM
cowmilker08's Avatar
cowmilker08
Its possible that the selector valve down on the frame rail is stuck on the rear tank.
Old Nov 10, 2015 | 12:37 PM
madpogue's Avatar
madpogue
^^^^ +1; important question - does the gauge reading change when you switch tanks?
Old Nov 10, 2015 | 01:41 PM
compaddict's Avatar
compaddict
Yup, it switches.
Old Nov 10, 2015 | 04:33 PM
madpogue's Avatar
madpogue
And the gauge always reads empty when you're switched to the front tank?
Old Nov 11, 2015 | 09:55 AM
compaddict's Avatar
compaddict
Yes. The gauge was a bit wonky at last fill up too. It read lower than what I thought was in the tank.
Old Nov 11, 2015 | 11:47 AM
madpogue's Avatar
madpogue
So it reads too low when it's full, and empty when it's partway full? Classic float failure; it's partway filled with fuel. The teeniest tiniest pinhole will do it. Last one I pulled, I couldn't actually find the hole. No matter which way I oriented the float, I couldn't get fuel to just drain out of it. But there was fuel in it no doubt. It would only come out when I shook it.
jeremywatco
Jul 5, 2019 06:02 AM
jdworley
Mar 26, 2017 02:11 PM
jbk
Aug 10, 2012 08:08 AM
Gil Chesterton
Oct 25, 2005 10:09 AM
hunter4evr
Jul 3, 2003 10:09 AM
