[updated:LAST EDITED ON 30-Aug-02 AT 10:24 PM (EST)]>A good way to shut somebody up is to stick a straight pin
>into his coax. As soon as he keys his mike his radio is
>fried.
>A little "truck stop" trick there!
That does'nt always work it's easier to just cut it.
Wiz
"Fear leads to anger;anger leads to hate;hate leads to suffering"........Yoda
if ya cut it, the signal will still get out out, albeit not as strong as with the antenna, but if you put a pin in the coax, it shorts the dieletic right to ground, thereby frying the final output(s) on the radio in question....and after that, if it's a straight cb radio(not a 10 meter conversion) it wont recieve as well ;-)
