NP205 grinding....
Old Nov 7, 2015 | 12:19 PM
Anthony487's Avatar
Anthony487
NP205 grinding....
I posted before about this but now that i was forced to use it today, i have new information.
My transfer case shifts into all gears just fine. with and without hubs locked.
In both 4L and 4H it goes into gear all the way just fine. around the 30mph mark, a light grinding occurs. The road stayed the same, accelerator stayed the same and the shifter was never touched, it would grind for a second or two then stop. There was no pattern and i could not get it to grind purposely. While it was grinding i put light pressure o the shifter in both directions and it didn't help. And its a very light grinding, not a stop the truck something is coming apart grinding
Has anyone had a problem like this?
Old Nov 7, 2015 | 03:53 PM
tbear853's Avatar
tbear853
Are you running the truck in 4lo or 4hi on a dry road with hubs locked when this is going on?
Old Nov 7, 2015 | 07:38 PM
PA74F250's Avatar
PA74F250
My 79 does that if its not in gear right. I know you say "correctly" but even when it feels like mine is right it's sometimes not I have to play with it a little to get it to stop making noise. I have more problems trying to find 2 hi more than anything.
Old Nov 7, 2015 | 10:10 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on NOT using 4H or 4L on a paved solid road for sure. Dirt, gravel and snow covered. 2wd to 4wd H when rolling is ok, but 2wd to 4L you should be dead stopped.
Have you checked the fluid level and condition? Stick a pinky in the top fil port and you sound just get the tip wet. lol
Also before you add it, get a good sample and see if it smells burnt, and it is 89/90 gear lube and not just motor oil?
Have you ever got it hot and did a drain and flush and see what is in the catch screen? Pieces of gear teeth, roller bearing parts and pieces? A froze bearing can cause havoc to the race.
A light occasional grind could be sticking roller bearing due to rust. When you hear and have the grind have you ever temp checked the xfrecase? Spray water to see if it will boil it?
Old Nov 8, 2015 | 12:01 PM
Anthony487's Avatar
Anthony487
i have tried 4L and 4H on gravel not dry pavement. i know not to do that. I was on ice when i had to use it the other day. when i rebuilt the truck, about a year ago, i just resealed the transfer case. the oil wasn't bad that came out of it and everything looked great on the inside. I did check the oil yesterday before posting and its clean and full. I haven't done the temp check but i can.
What still gets me is how light the grinding is and how it randomly does it for a second at a time. no pattern or specific time
Old Nov 8, 2015 | 05:21 PM
77&79F250's Avatar
77&79F250
Might be a bearing that is locking up on you? Have you done a drain/flush and filter of the drained oil insp for metal shavings? That is a tell tell sign of something wrong in there.
My silver 77 xfer case works great, shift great, and has no grinding sounds coming from it. But after a long road trip (1hr +) it will get hot enough to boil water sprayed on it....
Old Nov 8, 2015 | 08:11 PM
Anthony487's Avatar
Anthony487
I will do the drain and flush to see, i will also see how hot it gets, thanks!
jereli
Nov 20, 2016 10:49 PM
gartlesby
Aug 27, 2016 06:24 PM
Anthony_A
Aug 17, 2015 12:08 PM
Hondasucks
Feb 10, 2006 03:03 PM
perryphilip
Nov 14, 2003 01:13 PM
