timing
Old Feb 24, 2008 | 09:36 AM
albung's Avatar
albung
timing
IS it posssable to have dist 180 out when changing a timing chain? didnt pull dist loned up dot to dot and rotor was pointing at #1, im thinking is out 180 but not shure
Old Feb 24, 2008 | 05:22 PM
Handegard's Avatar
Handegard
The disty wouldn't move 180* unless you rotated the crank or cam while the chain was off. The disty's relationship to the cam would be unchanged, so you're talking about the chain timming being incorrect.
I assume you did a new timming chain, and now it doesn't run right? The most logical explanation would be that the chain is incorrect...
