They used to be steel with slant cut, fine teeth and no advance/retard. When they went to the fiber gear, they used coarse teeth and had a 4 degree retard.
mine has the composite helical cut gears. the older ones i belives did use the steel gears and switched to the composite because they were quieter. but yes, they are all good ol, never breakin a chain/belt, gear drivin cam gear.
Originally posted by Silver Streak The old fine tooth gears with straight up timing will bolt right on the EFI engines won't they?
The question has been asked but never answered as to whether the metal gears will interfere with the knock sensor on the EFI engines. The general opinion is probably not but no one knows for sure.
The other issue is that the phenolic gears are not up to handling the increased valve train loads from aftermarket cams, so a cam change must include a gear change.
I don't know about the EFI engines, but I know the steel gears will fit where the fiber gears came off. I wouldn't think that having steel gears would make enough vibration to mess with the knock sensor, but I could be wrong.
About six months ago my fiber timing gear exploded and left my truck down for three weeks. The shop that fixed it said the cam and lifters were worn out and needed to be replaced. (Had that knocking diesel sound.) I had the option of steel or fiber gears and decided to use the fiber. The shop said the cam and lifters may have caused the timing gear to fail. Not quite sure how but was about a $1000 shop bill. Now the truck seems slower than it did before. Wish I went with a better cam than stock. maybe the steel gears would have been a better choice but too late now. I think they were close to the same price.
