Need help with electrical problem
Old Nov 5, 2015 | 11:21 PM
No1rascal's Avatar
No1rascal
Question Need help with electrical problem
Hello to everyone, newbie with first post. Recently acquired a 61 f100 shortie project & need some help with a strange electrical issue.
I started looking into why the fuel gauge wasnt working. Found that on the lead on the gauge that connects the orange wire to the float has a pulsating current to it, same for the temp gauge. I have no idea where a pulsing current would come from.
Any ideas, suggestions, or info would be most appreciated.
I did order a color wiring diagram so hopefully that will help with some of the trucks wiring issues.
Thanks
Scott
Old Nov 5, 2015 | 11:53 PM
Tedster9's Avatar
Tedster9
Welcome to FTE!
The pulsing voltage is normal. It's coming from just behind the gauge cluster, a little charmer called the ICVR, or Instrument Constant Voltage Regulator.
Old Nov 6, 2015 | 04:25 AM
jowilker's Avatar
jowilker
Scott Welcome to and the Slicks Forum.
Hopefully the guys here will help get your issue solved shortly.
John
Old Nov 6, 2015 | 07:29 AM
hiball3985's Avatar
hiball3985
Start by taking the wire off of the tank sending unit and use a jumper or similar to ground the wire, when grounded the gauge should go to FULL. If it does the problem is in the sending unit or float that has sunk.
Old Nov 6, 2015 | 11:53 AM
No1rascal's Avatar
No1rascal
Thanks guys, never would have thought it was normal.
Z_Silas
Sep 15, 2018 07:58 PM
gavin68
Dec 9, 2017 10:01 PM
Highboy74
80
Mar 19, 2013 10:16 AM
bamboo321
54
Jul 16, 2012 10:54 PM
59INA40
Dec 5, 2005 08:48 AM
