'89 with a dead spot
Old Nov 5, 2015 | 01:26 PM
ramenth's Avatar
ramenth
Been wracking my brain on this one.
'89, 302, 5 speed truck has a dead spot where it won't wind past 2500-2600 rpm. Rail pressure is 32# at idle, 40# all in. Tested the ICM, it's good.
Been that way for a little while now. When I first got the truck, I could fly up a mile long 7% grade in 5th doing 65 and still have enough throttle to pull harder. Now, I'm lucky to make it up the same grade at 35mph, because the flat spot is forcing me to short shift to keep it under the dead spot.
Have a feeling I'm overlooking something obvious, just can't put my finger on it.
Old Nov 5, 2015 | 02:08 PM
88XLTLariat's Avatar
88XLTLariat
Have you checked your plugs,wires, and distributor cap? And what's your timing set at?
Old Nov 5, 2015 | 07:19 PM
ramenth's Avatar
ramenth
Plugs, wires, and cap are all less than 30k miles old. No misfire, just a dead spot, and no ignition break up. Gonna check the timing tomorrow. My old man has my timing light. He's coming over to help me with some house remodeling.
Old Nov 5, 2015 | 07:25 PM
88XLTLariat
Great. Check back in later and let us know what you find out.
Old Nov 5, 2015 | 08:49 PM
MR KROGOTH's Avatar
MR KROGOTH
Possible crossfire? Doesnt really sound like it though.
I had a fairly similar dead spot shortly before my original ignition module died.
Old Nov 5, 2015 | 09:20 PM
timbersteel's Avatar
timbersteel
Original dual catalytic converters?
I wonder if one is plugged?
Old Nov 5, 2015 | 10:42 PM
javlin's Avatar
javlin
If fuel good would be my guess but how can you one see the fuel pressure up a grade?I have an 89 same exact setup tank 2 causes alittle of an issue on grades but getting better thinking the DFR but it also causes a problem Sometimes when taking off in 1st gear under a load much like the hill then clears up when the pressure is on.
Old Nov 6, 2015 | 09:05 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Pull your PCM, open it up, and check for leaking capacitors. If it's still the original computer, it's a good bet the capacitors are leaking and that can cause unpredictable behavior.
Old Nov 6, 2015 | 10:19 AM
rla2005's Avatar
rla2005
Get a fuel pressure gauge with a long enough hose so you can tape it to the windshield to view while driving. I've done it for years.
Old Nov 6, 2015 | 10:40 AM
javlin's Avatar
javlin
Never thought of the windshield .Thanks.
SteelCitySeth
Oct 25, 2017 02:40 PM
Pilgrim
Dec 28, 2005 08:25 AM
bugser
Oct 11, 2005 12:29 AM
Catfish369
Bronco II
Sep 15, 2004 11:30 AM
h-m
Apr 1, 2004 09:50 PM
