Weird DEF Issue
Old Nov 26, 2015 | 04:36 PM
montey2005's Avatar
montey2005
Originally Posted by bigredtruckmi
Def showed 240 miles to empty. Filled and only got 2 gal in tank.
how do you get it to show mileage? Mine only has OK and the inevitable 500 miles to empty, granted only twice. Oh and the pump failed so they had to replace it.
Old Nov 26, 2015 | 06:21 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
It showed miles on startup.
Old Aug 16, 2020 | 04:12 PM
mspenc45's Avatar
mspenc45
I own a 2019 F350 that suddenly showed the DEF was full when I knew it had only a half tank the day before. Took her in under warranty and she spent a week at the dealership trying to diagnose the problem. They tried multiple things like changing the level sensor, etc. When that did not work, Ford was contacted and the dealer did several checks on the system, including wiring. They ended up changing out the entire tank and the system supposedly worked, but here I am three weeks after this fix, about 1200 miles, and the DEF level still shows full. Coincidentally, or not, the real reason I brought the truck in was that my EGT temp sens No. 1 had a fault. They found that a rat had chewed through the wire, but emphatically said there was no wire damage to the DEF tank level wiring. Wondering if anyone else has experienced this reading of full when not, or have any ideas?
Old Aug 19, 2020 | 10:39 AM
HRTKD's Avatar
HRTKD
The DEF level has a tendency to be a bit slow to report changes. Then again, A full tank of DEF should last an average of 5,000 miles on a 2017-2019 truck. I would give it more miles before raising a red flag.
Old Aug 19, 2020 | 10:44 AM
mspenc45's Avatar
mspenc45
Thanks for the insight!
U235Fishin'
6.7L Power Stroke Diesel
Aug 1, 2018 10:14 AM
aksundog
Jun 12, 2015 05:28 PM
marcs724
Dec 21, 2012 05:00 PM
KC8QVO
17
Oct 6, 2011 09:19 AM
ruschejj
13
Mar 18, 2011 06:09 PM
