TPMS on Dually's
Old Nov 4, 2015 | 08:15 AM
Joe/GA's Avatar
Joe/GA
TPMS on Dually's
Hey guys. On my last trip pulling our 5th wheel. I got a bolt through my inner left dual and it lost all air. There was never any alarm. Don't the dually's have TPMS on all 6 tires? Mine is a 2015 Lariat.
Old Nov 4, 2015 | 08:35 AM
jonrjen's Avatar
jonrjen
I would be willing to bet that your dually does not have TPMS installed as they are not required by the government due to being over the magic GVWR number.
There are many different aftermarket systems that can be added should you so desire
Old Nov 4, 2015 | 08:40 AM
sdetweil's Avatar
sdetweil
duallys do not have TPMS.
we added an TruckSystems (tst) 507 system with 6 sensors and 4 for the FW.
Old Nov 4, 2015 | 03:05 PM
Joe/GA's Avatar
Joe/GA
Hmmm...that explains that. It just happens that I have a TST TPMS system on the truck and the 5th wheel, but the left front and inner left dual quit working. The outer left dual went into alarm because the temperature was going high. That was my only clue to a problem.
Thanks for the explanation!
Old Nov 4, 2015 | 03:23 PM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
Sam,
Did you re-balance your wheel/tire combo when you added the TPMS ?
Thanks
Keith
Old Nov 4, 2015 | 04:34 PM
Just Strokin's Avatar
Just Strokin
I have the TireMinder/Camping World TPMS 66 system. Did not have to re-balance after install. I have senders on all 7 of the truck's tires and all 5 of the 5th wheel's tires. IT did come in handy on my trip from Alabama to Washington State and back. I had one of the metal valve stems come loose and the tire lost 10psi fairly quickly. It gave a warning and I pulled over immediately. Was able to tighten the nut on the valve stem and proceed to the next exit where i could safely pump up the tire.
Out of habit and knowing some of the sensors do tend to stop or battery go bad, I do a manual reset of my TireMinder system and let it re-find all the sensors. If any do not report after 30 minutes, I check them for bad battery or other issues.
Old Nov 5, 2015 | 07:17 PM
sdetweil's Avatar
sdetweil
Originally Posted by ZooDad
Sam,
Thanks
Keith
No, I have balance beads, and the stainless hose extensions
Old Nov 5, 2015 | 10:28 PM
don.joyce59's Avatar
don.joyce59
I also have TST 507 on my dually and 5th wheel. Worth the peace of mine.
Rscottc
Jan 18, 2015 09:07 PM
Medic 66
Apr 24, 2006 11:21 AM
460f250
Nov 6, 2005 09:18 PM
bigtoy
Aug 27, 2000 11:18 AM
