2001, F250, 2 WD, 7.3, Manual 6 speed transmission, Lariat.
I drive 24 hrs a day with the headlights on.
Problem= With the lights on in daylight I can't read the radio/clock panel and I can't read the compass, MPG/other stuff on the roof mounted display .
Solution so far = Turn off lights in daytime to read those things.
Is there a wiring change that I cam make to solve this problem?
Thanks, Marvin
I had the same problem with factory head unit and when my overhead display worked. cant read it with lights on. Im not sure about the head unit, but i know somewhere on here is a how-to for the overhead display to be on full brightness all the time. ill try to find it
