Anyone add the 115v in-dash outlet?
only a few things needed. I plan on trying to add one to a 2016 Fusion I have on order.
You need the inverter, and the 115v dash plug and any harness. Might be one or two harness. Not sure if the inverter has the cable as part of it to supply power to the dash plug. You will also need the harness to connect the inverter to the truck dash harness.
Here is the part number of one of the inverters. Lariat and higher interior packages have 2. Not sure if they are the same number or not.
BC3Z-19G317-A
here are a few on eBay
http://www.ebay.com/sch/i.html?_odkw...+duty&_sacat=0
http://www.ebay.com/itm/HYBRID-CONVE...ZRzZhM&vxp=mtr
BC3Z-19G317-A
you would need a large (500 to 1000 watts) inverter to power an air compressor.
You could just get the dash outlet and harness for a clean install if you like that location, and run it to a stronger inverter you hide somewhere. Upside is you could also wire in outlets in the back for a compressor or anywhere else they would be handy.
Take a look around the RV sites for some ideas/parts. They would have the correct wiring to run, etc.
I like this idea. Then I could put an outlet in the back seat area and potentially one in the bed. I could wire it to one of the Upfitter switches to have another level of safety.
I have a small inverter that I plug into my cigarette lighter to charge small electronics that only came with a wall charger. It will charge them but you can't run them on the power it puts off. I have a larger 1500 watt inverter that I run my larger appliances off of. Like mentioned above, it has battery cables that hook directly to the battery and I run them through a hole in the floor. I have multiple batteries and leave my rig running , so no danger of draining my batteries.
zspeed130
02-25-2014 08:15 AM
BlackWidowMotorSports
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
12-13-2003 10:35 AM
