Using oil ?
Old Nov 2, 2015 | 11:09 AM
B85's Avatar
B85
Using oil ?
She is a 1999 7.3 T,with 210000 miles. Runs great BUT I'm using oil. Very little oil smoke in the exhaust. Looks about the same as it has been forever ? Can see some oil film on intake/outlet turbo hose's ?
I'm thinking its the turbo seal ? Did a pull with my tractor of about 200 miles round trip. Trailer is about 10,000 #. Used about 1 1/2 Qt's. Good power and no blue smoke that I could see.
So is it time to R&R the seal's or replace turbo ?
I'm new to diesel but have been taking care of it for the last 10 years.
Thanks for any input !
Randy
Old Nov 2, 2015 | 01:26 PM
z31freakify's Avatar
z31freakify
If you dont have excessive blow by it might just be your injector o rings a turbo rebuild is not hard at all, plenty of threads about rebuilding good luck
Old Nov 2, 2015 | 09:04 PM
jhl3's Avatar
jhl3
Agreed. Injector o-rings would be at the top of the list if you don't see an excessive leak anywhere, especially if the o-rings have never been changed.
What did/does your fuel filter look like when changed?
Old Nov 2, 2015 | 09:09 PM
B85's Avatar
B85
I'm leaning that way. What am I looking for in the filter ?
Randy
Old Nov 2, 2015 | 09:11 PM
jhl3's Avatar
jhl3
Your fuel filter should be black on the outside if your injector o-rings are tired and if you still have the stock fuel system.
Old Nov 2, 2015 | 09:35 PM
B85's Avatar
B85
Ok, its all stock.
So I need Inj. seal kits for 8 ? I redid the heads 2 years ago,do you think I will need new valve cover gaskets ? Anything else needed ?
Was thinking, with the miles maybe I need to do the turbo also ?
Old Nov 2, 2015 | 09:58 PM
jhl3's Avatar
jhl3
As long as the valve cover bolts weren't severely over-torqued, you should be able to reuse them.
Did you replace o-rings on the injectors when you did the heads?
It won't hurt to do the o-rings on the turbo.
Did you replace the glow plugs when you did the heads? If not, it takes about an hour extra if you are doing o-rings and costs about $100. Use only Ford OEM for both o-rings and glow plugs.
Dieselorings.com
Motorcraft Glowplugs ZD-11 - Ford 7.3L (94-03)
Old Nov 2, 2015 | 10:04 PM
B85's Avatar
B85
Had the Inj's flow tested and cleaned. Think the O rings were NAPA ? Also the glow plugs about a year before the heads.
How about "www.RiffraffDiesel.com" for the parts?
Old Nov 2, 2015 | 10:13 PM
B85's Avatar
B85
Dup, sorry.
Old Nov 2, 2015 | 10:16 PM
jhl3's Avatar
jhl3
OK. Depending upon whether NAPA was supplying OEM or not, my bet is that they are not, then it could still be o-rings.
Riffraff is an awesome place to spend money!
Old Nov 2, 2015 | 10:20 PM
jhl3's Avatar
jhl3
Alliant Injector O-rings - Ford 7.3L Powerstroke (94-03)
Old Nov 2, 2015 | 10:32 PM
B85's Avatar
B85
Yep,8 of the O ring kits, one turbo seal kit and thinking about the Riffraff Diesel Billet Compressor Wheel 94-03 ?
Old Nov 2, 2015 | 10:35 PM
B85's Avatar
B85
Will pull the filter cover in the AM. What is the torque on the cover when I reinstall it ? I have the tool but not sure about the torque.
Old Nov 3, 2015 | 07:12 AM
jhl3's Avatar
jhl3
I have looked and I cannot find a factory recommended torque spec. So, hand tighten until the seal makes contact and gets snug, then go 1/8-1/4 additional turn and test for leaks.
Old Nov 3, 2015 | 08:29 AM
B85's Avatar
B85
Thanks for looking !
Randy
