Need help with a bent rim
Old Nov 2, 2015 | 09:43 AM
mr.precision's Avatar
mr.precision
The '41 has a chevy disc brakes on the front, with the usual 5 on 4-3/4" bolt pattern. One of the rims is bent, and I am struggling to find another that matches. Vintique wheels don't match. Any ideas? Wheel is 15 x 7 with a 4" backspace. Note the dimples for the hubcap and the slots between the rim and the center.
Thanks in advance.
Old Nov 2, 2015 | 10:29 AM
51504BAT's Avatar
51504BAT
Thanks in advance.
There used to be shops that straightened rims. Don't know how bad your rim is or if there are any shops in your area that still do this sort of thing but its a thought.
Old Nov 2, 2015 | 01:49 PM
tinman52's Avatar
tinman52
Welder User
They look similar to GM full size RWD of the 80's. Impala, etc. Most wheels have part numbers stamped on them, if you can find it. Searching that number will turn up what they were used on.
Old Nov 3, 2015 | 02:19 AM
willowbilly3's Avatar
willowbilly3
I agree, 80s or maybe even 90s Impala. There were no 15x7 stock steelies that I know of any earlier than mid 80s. Probably cop car wheels earlier than the 9C1 Impala but may have came off the older square Caprice 9C1
Old Nov 3, 2015 | 08:28 AM
mr.precision
Thanks Tinman and Willowbilly. Good tips that are a great place to start. The bent rim isn't repairable, so I gotta find a matching replacement.
Schickel
21
Nov 2, 2020 04:57 PM
FordsOnlyGarage
Jun 15, 2017 07:05 PM
moose79
Jan 8, 2016 03:22 PM
markjw
Feb 23, 2007 12:44 AM
kirincat
Mar 27, 2005 10:38 AM
