Project technical support required - heater plenum replacement
Old Nov 1, 2015 | 06:53 PM
thejean's Avatar
thejean
Hi Folks, Feeling a little defeated right now and looking for some support to help me get through this. Here's the issue - my defrost is isn't working and as per TSB 13-2-9, the heater plenum and blower unit need to be completely replaced. I'm probably the first numbskull to try this on my own so figured maybe we can make a bit of how-to out of this thread. Anyway, what I have done so far is remove the dash and unbolt the dash bracing. I'm trying to remove as little items as possible so that I don't have to remove quite as much wiring. Anyway, I can now see most of the heater plenum and removed the top bolt and nut over by the defrost unit. But the damn plenum still won't budge and I can't see any other nuts or bolts holding it in. Keep in mind I haven't removed the coolant hoses as I wasn't sure if I would have to slap it halfway back together to take it somewhere so they could be holding it down somewhat but I would think it would at least move a bit. Is there a trick to this or something? Anyway, please please please someone help me figure this out!? Thanks! JC
Old Nov 1, 2015 | 06:54 PM
thejean's Avatar
thejean
This is where I got to so far. Ugh.
Old Nov 2, 2015 | 03:10 PM
darren32's Avatar
darren32
WOW that don't look good
I believe you need to access some of the bolts from the outside by removing the RH fender splash shield.
Good luck!
Old Nov 2, 2015 | 04:17 PM
thejean's Avatar
thejean
Yup, you're right. Some time consuming searching turned up this:
Old Nov 2, 2015 | 04:18 PM
darren32's Avatar
darren32
Let us know how you make out
Old Nov 2, 2015 | 05:55 PM
Tofan's Avatar
Tofan
Damn and here I was thinking I was bold and **** doing a leather seat swap. That's just awesome hahahaha.
thejean
6.7L Power Stroke Diesel
80
Jan 6, 2018 12:17 PM
Clem's Cousin
Dec 20, 2014 05:59 AM
78 & 87 Super Cab
Jan 23, 2013 07:36 PM
PRUSue
Nov 29, 2010 03:43 PM
Native Gearhead
Oct 27, 2003 11:48 AM
