Sponsored by: Innova
Removing door panels...?
Old Aug 5, 2003 | 01:23 PM
mzimmers's Avatar
mzimmers
Hi, all -
Who knows how to remove the door panels? I found two screws at the bottom, but removing those made no difference; the door still held fast. Before assuming that it's merely clipped in, I thought I'd consult my favorite panel of experts...
Old Aug 6, 2003 | 11:23 AM
scottpower's Avatar
scottpower
Been in my 98 Mountaineer doors after watching a body shop pull one to change out a mirror. Once any screws are removed (my front and rear had two each securing the arm rest / window, lock controls panel) it is held to the door by 10 or 12 plastic push pins (my name). Pry out the bottom (scratch won't show no matter what tool you might use) get your fingers under the panel, move to where there is resistance (a pin location) and pull out. Go around the door and pull all. The pins might seperate from the panel rather than the door but you can pull them from the door and reinsert them in the panel later no problem. The upper portion has a lip over the window (oops, start with the window down) opening so raise the panel to release...
Old Aug 6, 2003 | 04:15 PM
cgl's Avatar
cgl
If my memory serves me right... My 02 350 had two screws. One under the red light/reflector and one under the power window/lock panel (should snap right up). Then all I had to do was lift the whole panel up and off. Easy as that!
billy13
Dec 14, 2009 10:29 AM
Bluze
Feb 6, 2009 01:47 PM
dmcenery
2004 - 2008 F150
Oct 25, 2008 09:52 AM
tutiii
1997 - 2003 F150
Sep 17, 2007 09:41 AM
cutlac
Jan 8, 2005 02:21 PM
