1963 144 I6 Info
Old Oct 31, 2015 | 11:27 AM
4x484150's Avatar
4x484150
1963 144 I6 Info
Hello, I'm usually over on the 80-86 Truck section, but had some questions about the air cleaner set up on a 63 Falcon. (I know its not a Ranchero, but I think its basically the same?)
So the engine is a 144. I was wondering if there is some type of hose that runs to the air cleaner? The cleaner itself has a short round snorkel on it.
I was also wondering if there is a hose that connects from the oil fill to the cleaner. There is a small 90* tube on one side of it.
Sorry I don't have any pictures at the moment, I may be able to tomorrow.
Thanks in advance!
Old Nov 1, 2015 | 01:40 PM
tjc transport's Avatar
tjc transport
i ain't rite
no hose off the air intake, back then they just drew air out of the engine bay.
not sure on the 90 in the filter though, my 170's and 200's did not have them
Old Nov 1, 2015 | 04:05 PM
85e150's Avatar
85e150
Hose from aircleaner to oil fill would be the fresh air supply for the PCV system. CA cars had those in '63, maybe earlier. Do you have a PCV or hole for one in the valve cover? Could be an air cleaner off a later model too.
Positive Crankcase Ventilation (PCV)
Old Nov 1, 2015 | 04:40 PM
tjc transport
i ain't rite
PCV goes into the intake manifold at the bottom of the carb.
or it would have a road draft tube off the front of the block if it was a non PCV engine.
Old Nov 2, 2015 | 03:59 AM
4x484150's Avatar
4x484150
Thanks for the responses! There is not a separate hole for a PCV in the valve cover, just the oil fill. And I didn't know the name for it, but it does have the road draft tube. You can see light "exhaust" coming out of it when its warmed up.
Old Dec 31, 2015 | 01:45 PM
4x484150's Avatar
4x484150
So it took me a while, but I have the pictures of the engine.
Still not sure about this air cleaner.
Old Dec 31, 2015 | 04:18 PM
tjc transport
i ain't rite
never saw one like that on any of my 14 falcons.
Old Dec 31, 2015 | 07:07 PM
4x484150's Avatar
4x484150
Do you have a picture of what should be there?
Also, the air cleaner has a stud on the bottom, that goes into the bracket showing on the last picture.
I know that this car has not been messed with in the last 28 years, but there is the history before that, that I have no clue about!
My dad has owned it the whole time, and an old lady owned before that.
Old Jan 1, 2016 | 09:53 AM
tjc transport
i ain't rite
unfortunately i have no pictures of my old cars, i lost everything years ago in a flood.
Old Jan 2, 2016 | 03:50 PM
4x484150's Avatar
4x484150
Thanks anyway. I'll do more research, and find NumberDummy. See if he can help.
Edit: Tried to ping NumberDummy, and he doesnt receive PMs.
Old Jan 14, 2016 | 07:38 PM
JAhearne's Avatar
JAhearne
You have the wrong aircleaner on there. Your 144 has a draft tube coming off the block; that's all the crank ventilation there is for the legendary Falcon six.
Normally, that 90 degree tube off the aircleaner would attach to the oil cap and a PCV valve would attach to the carberator base.
Check out Fordsix.com/forum
Old Jan 19, 2016 | 01:07 PM
4x484150's Avatar
4x484150
Thanks for the reply, I thought(as does my Dad) its the wrong one. I'll check out that forum.
aedinius
Apr 24, 2015 12:04 AM
bowtieman55
18
Nov 11, 2014 12:45 PM
CTom
Jul 1, 2014 12:37 PM
i looove fords
Feb 9, 2003 05:30 PM
haleakala
Aug 14, 2001 11:33 AM
