6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
P0194 fuel rail sensor erratic
Old Oct 30, 2015 | 07:39 PM
Archy's Avatar
Archy
2008 6.4 Got this code yesturday and the truck idled rough and died started it back up and it does it intermittent is this possibly just a sensor change under the valve cover or fuel pump ? I was going to change the sensor tomorrow and go from there. This is the only code I could pull fuel rail pressure was right at 5750 at ideal and went up to 7-8000 just giving it a little fuel the voltage for the sensor is bouncing from 1.18 - 1.22 volts running koeo .50
Old Oct 31, 2015 | 06:42 PM
cheezit's Avatar
cheezit
Iirc sensor and under valve cover harness.
Old Nov 4, 2015 | 07:44 AM
Archy's Avatar
Archy
Ok I changed the sensor and the wet harness but when I pulled the sensor I thought fuel would come out but it was dry ? Is that normal
Old Nov 4, 2015 | 05:54 PM
cheezit's Avatar
cheezit
You will only have fuel there if there is pressure at the line. So what you have is normal.
quality1construction
Aug 11, 2017 06:44 PM
Resalto.jones
May 15, 2015 06:18 AM
Resalto.jones
May 14, 2015 04:14 PM
bashby
13
Aug 11, 2012 06:52 AM
TJN
1983 - 2012 Ranger & B-Series
Oct 1, 2003 07:50 PM
