E40D hard shift in every gear
Old Nov 24, 2015 | 01:30 PM
Scndsin's Avatar
Scndsin
The airbag diagnostic module. Did you open it up?
Old Nov 24, 2015 | 01:54 PM
Luvmifordpu's Avatar
Luvmifordpu
ADM
Notice spots on large cap. Indicates blown cap.
Old Nov 24, 2015 | 02:53 PM
Scndsin's Avatar
Scndsin
Thanks. I'll add this to a list of failing electronics to check in the future. Just went through some stacked failures with caps in the ecu coupled with psom problems on top of Vss code that wasn't the problem.
Old Nov 24, 2015 | 06:23 PM
Eddiec1564's Avatar
Eddiec1564
If you are talking about the green disk that looks cracked, that is not a capacitor but a MOV( metal oxide varisistor). They act like a over load fuse and will short out if voltage is spiked beyond it's rating.
Unless you got hit with lighting/high voltage surge for which MOV's are mostly used for, it likely failed due to age.
Kevin562
Nov 29, 2023 12:10 AM
beeshoo
Jun 6, 2021 09:18 AM
Southern Buckers
79
Jan 24, 2020 12:31 PM
bronco up
1978 - 1996 Big Bronco
Feb 18, 2004 06:24 PM
starplex
Electrical Systems/Wiring
Jun 30, 2003 10:46 PM
