I wish
Old Oct 27, 2015 | 09:21 PM
wrhinehart's Avatar
wrhinehart
I wish
I wish there were some way for the Administrators to place into separate folders the various posts here.
On folder for Exhaust issues, 1 for ignition, 1 for timing, 1 for carburetion etc..
That way guys and gals with issues could easily find answers without going through hundreds of posts.
just thinking
Old Oct 27, 2015 | 10:01 PM
Tedster9's Avatar
Tedster9
That sounds OK. Or maybe "Help! Won't Start!!" section. But, there are already way too many forums as it is. A fair number of folks find it difficult to post in the proper forum.
Old Oct 28, 2015 | 03:18 AM
jowilker's Avatar
jowilker
Aint that the truth.
John
Old Oct 28, 2015 | 06:54 AM
HIO Silver's Avatar
HIO Silver
Fordification is organized that way. I think there are advantages and disadvantages.
Perhaps it's the way you search. ALWAYS use the advanced search feature. Narrow your search to a specific forum and use detailed key words.
Just using the search box above results in a search of all of FTE.... and FTE is very active.
Old Oct 28, 2015 | 06:57 AM
Coastal68's Avatar
Coastal68
Google almost always turns up posts from this site in a web search. Like this: https://www.google.com/search?q=1968...m=122&ie=UTF-8
You'll notice under the short list of results from FTE a "More results from www .ford- trucks. com" button. Click it and scroll through till you find what you need.
This has worked pretty well for me on numerous occasions. Most of my questions have already been posted here so I don't need to start my own thread. The workaround is handy since the FTE search function is, well... not so great.
Old Nov 3, 2015 | 10:06 AM
1972-34ton's Avatar
1972-34ton
Rabbit-Hole Researcher
I wonder if we might use a "local Google search" for this site only?
Old Nov 3, 2015 | 01:29 PM
TeachNlive4ever's Avatar
TeachNlive4ever
I have great difficult navigating thru the FTE searches, too. As 1972-34ton said, I google search it and it leads me to FTE
Old Nov 4, 2015 | 10:16 AM
willowbilly3's Avatar
willowbilly3
FTE already has a dizzying amount of categories, I don't think we need more. Search is your friend
Old Nov 4, 2015 | 09:10 PM
Swaybar1's Avatar
Swaybar1
maybe a genie....
I was trying to solve a transmission issue but after searching through about eight pages of threads I gave up. A google search did help but in the end I decided to post, a probably, incorrectly posted thread
1967 Ford Camper Special
Old Nov 4, 2015 | 10:02 PM
willowbilly3
If you did a google, it should have taken you to a certain 67-72 forum where the information is categorized in separate "folders" like you mentioned and I bet you would have found the information there. Not trying to run you off, just saying, there is good information on almost everything if you are willing to take the time to find it.
Old Nov 5, 2015 | 12:04 AM
Ford_Six's Avatar
Ford_Six
There is a quick Google shortcut for searching, basically just enter your search terms then a space and site:ford-trucks.com, and it will search only this site.
smallello
Dec 14, 2016 12:23 PM
bobj49f2
Apr 27, 2009 06:13 PM
79CEEJAY
Dec 4, 2002 10:00 AM
