trans shutter
Old Oct 27, 2015 | 05:37 PM
Bird-Dog 250's Avatar
Bird-Dog 250
trans shutter
Has anyone encountered a shutter from what appears to me as something originating from the drive line under load? Living in the Smoky Mountains I'm going over the mountains quite often. Under a load condition, up one of the 9% grades for instance, with or without a load and under throttle my 97 F250 7.3 has a shutter to it. You can feel it in your seat. I'm hoping the trans is not about to give up the ship!!!???
Old Oct 27, 2015 | 09:24 PM
nwjones18's Avatar
nwjones18
I'd dump a bottle of lubguard red in it and see what happens.. The stuff has worked for me multiple times in the past.
Old Oct 28, 2015 | 05:38 AM
Bird-Dog 250
I did do that already. Since I did it I've driven about 60 miles or so. Does this stuff take some time to work into the clutch plates?
Old Oct 28, 2015 | 07:45 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If it isn't shifting when it's shuddering it almost certainly isn't the clutches in the transmission. It is much more likely to be a problem with the driveshaft, such as a failing u-joint or carrier bearing.
BURNSTOUGHFORD
1997 - 2003 F150
Aug 14, 2008 07:30 AM
Truxx1956
16
Mar 28, 2008 11:17 PM
ALBUQ F-1
May 15, 2007 04:46 PM
r0cky
Jun 7, 2004 07:51 PM
will420
1983 - 2012 Ranger & B-Series
Apr 18, 2004 02:31 PM
