4x4 issues
Old Oct 26, 2015 | 03:03 PM
whaase's Avatar
whaase
4x4 issues
I've been reading everything I can find about 4x4 not engaging. I have a 2004 F150. Last winter it just stopped working.
I changed the IWE solenoid as it seemed like a logical and inexpensive place to start. Didn't help
When I'm parked and running I switch to 4x4 Hi and I hear a faint click. I'm not sure how loud the transfer case motor should be when it engages?
I jacked the front of the truck up and put in it and out of 4x4 and my wheels spin freely either way.
Can someone direct me to my next step?
Thanks, Walter
Old Oct 26, 2015 | 04:48 PM
whaase's Avatar
whaase
I should also say that both 4x4 Hi and Low lights will come on.
Walter
Old Oct 27, 2015 | 04:15 PM
steve(ill)'s Avatar
steve(ill)
first thing that happens is the transfer case locks in and engages the front driveshaft. Put the truck in 4 x 4 and then shut the motor off. Jack one front tire an inch off the ground and see if you can turn the front drive shaft. If so, the transfer case did not engage. If the driveshaft is locked in, then rotate the front tire. If it does not rotate, the axle is not locked in. ............ motor has to be running and vacuum present to get the front axle OUT of 4 x 4.
Old Oct 27, 2015 | 04:40 PM
whaase's Avatar
whaase
Ah, I'm getting it. I'll check it out and write back
Thanks Walter
Old Oct 27, 2015 | 04:53 PM
whaase's Avatar
whaase
Ok, shaft locks in but I can rotate the tire. It did lock for a second then it freed up again.
I'm thinking the IWE actuators?
Walter
Old Oct 27, 2015 | 10:01 PM
steve(ill)'s Avatar
steve(ill)
yes, IWE is bad.... problem is they should LOCK when the motor is off and no vacuum.. You need to start the truck and put it in 2 x 4 to get it to disengage !! Your in the right area !
netminderone
2004 - 2008 F150
Feb 11, 2016 12:39 PM
wannaBelkhuntin
Nov 28, 2014 11:52 AM
classic19_98
1997 - 2003 F150
Sep 28, 2014 06:02 PM
bigdawg460
Mar 6, 2008 02:02 PM
truckmonger1
1997 - 2003 F150
Mar 20, 2007 06:47 AM
