Please help carb/fuel pump?
Please help me, I am getting desperate now.
I have a 1961 292 with the 2bbl Autolite carb.
My motor has gone south after running the best it has in a long time. It started by wanting to idle down and stall when I let off the gas when driving. It has gradually been more noticable.
So when I get it home, I start trying to figure it out. When I rev the idle to about 2500-3000, it will rev, then after about 5 seconds, even though my foot is in the same place, the rpms drop to about 1500, then drop to about 300 and just about die. If I just pump the gas pedal once real quick or wait a few seconds it will go back to 900 and idle like everything is ok. But now when I try to drive it it falls on it's face, and even seems to backfire through the carb.
Ok, stay with me, (please). I did notice that the see through fuel filter seemed to have less fuel than normal, and trickled through. But My gauge says that it is at 4psi. (I also got a good gas bath from it last night) Later the level seemed ok. I have already ordered a new fuel pump to maybe try, but now I am thinking carb problem. I was going to try a carb cleaner today as well.
When I hook my vacuum gauge up to the carb it is only pulling around 7-8. I have tried adjusting the screws, but can't get much more. If they are all of the way in the engine will die, so I know they are moving. What could cause such a low reading?
Initially it seems that the motor just wasn't getting enough fuel to me, and when the higher demand was let off, it recovered, but now I'm not sure.
The plugs are sooty, and I have recently installed the Pertronix ignition.
Help, I'm seriously considering a newer motor now.
Craig
So... I decide to plug the vacuum advance, and the problem disappears! Looks like a distributor problem, hopefully just needing a new vacuum advance, and not a Pertronix issue. If the new advance doesn't work, then I will try the points again. I have changed to a different plug. I guess that I am the last guy in the world to find out that the Bosch plugs totally suck *** in american cars. Thanks for recommending them Autozone guy.
Thanks, Craig
However, I don't understand why you blame the bosch plugs for the problem. I don't use bosch and I don't know that they are good or bad but they don't seem to be the cause.
Maybe the Bosch are ok, but if these new Autolite plugs don't foul as quickly I will post it so incase anyone is interested in plug usage, they will know.
I am forever searching the archives here for info, you know?
Thanks Craig
My initial timing is a little late now, but with the advance on it idles and runs good anyway. Could it be that the vacuum advance is out of the box adjusted and making up the difference in total advance? Should I go ahead and get my initial advance correct and then try to adjust the vacuum advance to run good? Or should I leave well enough alone? I'm leaning towards leaving it alone.
Thanks
Make sure your vacume advance is hooked up too the correct port on carb.
This should solve some of your problems.
Good luck HOTWRENCH
Craig
Hello, from the way you have described it, it sounds like fuel starvation. Many times i have seen where people will put a fuel filter between the fuel pump and carburetor...Guess what happens??? The fuel force actually crushes the inner element (even on clear see through filters that you cannot see with your eyes) and wala!@!!! Fuel can't get through during times of acceleration or when you hold a steady speed or will idle down gradually.. Be sure your fuel filter is the BIG ONE, and place it not between the pump and carb, but instead between the Tank and Pump (The suction non force side), that one error issue drives many people nuts because they change the fuel filter and get out and look and the flow is just dandy, but as pressure increases or idle continues it slowing gets less flow because of pressure forced element inside the filter because the filter is on the pressure side... Check that out, I fixed one at our shop about 3 years ago and a guy thought he needed a whole new ignition and tried this gauge and that reading and this and brought it to us, next day he nervously said, about what will this cost?? And i said 32 dollars hon, talk about a funny thing. I hope this helps you.....Janet
Craig
Mike
