Engine stops running
Old Aug 5, 2003 | 07:44 AM
SmilinJack's Avatar
SmilinJack
Unhappy Engine stops running
I have a 2000 F-350 SuperDuty with a 7.3 liter diesel which stops running after about two minutes and does this each and every time I start it. I've drained the filter bowl and change the fuel filter which did not help. I've also noticed the fuel pump solenoid gets extremely hot to the touch. If the culprit is the fuel pump would a pump other than FORD pump work? If so, where can I buy one....
Thanks
Old Aug 6, 2003 | 07:36 AM
SmilinJack's Avatar
SmilinJack
Addition... Found the fuel pump to be ok...just air in the supply lines. I thought I had run the engine enough to get all the air out but evidently not. After starting, stopping, etc. finally all is back to normal.
madtrashman
25
Dec 24, 2013 03:20 PM
1989fordguy
Feb 21, 2013 05:06 PM
drjoe171
Sep 20, 2010 06:04 PM
RedBarron89
Aug 4, 2010 07:07 AM
nwebbe1079
Jun 26, 2010 09:50 PM
