2001 expedition issues???
Old Mar 8, 2016 | 09:13 AM
  #31
R&T Babich's Avatar
R&T Babich
Originally Posted by deputydog03
... Finally found which coil was going bad. ...
Was the coil or the boot bad?
The coils don't usually go bad unless there is a crack in the case or such.
The boots which contain the high voltage pulse to the plugs or the spring getting rusty are often the issue.
Old Mar 8, 2016 | 09:15 PM
  #32
deputydog03's Avatar
deputydog03
It was the coil. A few months ago I did find a bad boot on this same cylinder, replaced that and it didn't fix the problem. Now with a different coil it runs good.
The coil that went bad was a Car Quest aftermarket coil. A couple of years ago the same coil went bad so I replaced it with one from the local parts store. This time I replaced it with a Motorcraft coil.
offrdmania
Sep 24, 2014 12:04 PM
Restlesswildman
May 19, 2014 04:46 PM
unclestevie60
Jun 2, 2010 04:23 PM
ajeffrey
Apr 4, 2006 11:35 AM
yama916
20
Jan 9, 2005 10:20 PM
