Sponsored by: Real Truck
Leveling Kit Question
Old Oct 24, 2015 | 09:21 PM
RainHellFromAbove's Avatar
RainHellFromAbove
For the 2005 F250 4x4, there are spacers available to put above the coil spring, and below the coil spring, to level the front with the back.
It either one better or worse, stronger or weaker?
Thanks
Old Oct 25, 2015 | 08:18 AM
jonrjen's Avatar
jonrjen
I used to own a 2006 F-250 2WD. I was going to level the front of the truck, but never got around to doing so. I did however purchased the spacers or as often referred to pucks to install at the coil springs.
If I can locate them and you are willing to pay the shipping your welcome to them. They are new and unused.
Just post here or send me a PM.
Old Oct 25, 2015 | 08:55 AM
Hotrod70d's Avatar
Hotrod70d
I have the ready lift level kit the sst 2.5 inch tow kit has 5 inch rear blocks. Works great looks good. No problems . Came with the correct drop brackets,sway bar ,track bar,shock brackets, brake line brackets,and driveshaft carrier shim, took about 3 hrs to install.its on top design. Like it better myself. Paid 325 for it new was asking 375 or 400 on eBay.
Old Oct 25, 2015 | 09:01 AM
Hotrod70d's Avatar
Hotrod70d
Sorry as I have no real pics of it lifted , I can seem to upload any or I don't do it right tried to even upload in past to my garage , they just don't seem to work for me
Old Oct 26, 2015 | 06:01 AM
NorEasterMA's Avatar
NorEasterMA
I added the lower spacer on my '06, an 1.5" unit from readylift. It's a block of aluminum and it replaces the lower spring perch, allowing the spring to sit higher. I prefer this style - it feels more sturdy to me and it's not visible when looking into the front wheel well.
rangergirl94
Nov 13, 2011 08:24 AM
jlcote
Jul 7, 2009 12:38 PM
04heritage4.2
1997 - 2003 F150
Oct 4, 2005 11:26 AM
04heritage4.2
Oct 2, 2005 11:55 PM
baw289
1978 - 1996 Big Bronco
Feb 24, 2004 08:26 AM
