Which do you guys think would look more "correct" on my 64 2wd flareside?
http://www.ebay.com/itm/351549771563?item=351549771563&frommaketrack=true&viewitem=&vxp=mtr
http://www.ebay.com/itm/Ford-center-caps-hubcaps-machined-set-of-4-3F23-1A096-EB/131144377974?_trksid=p2047675.c100010.m2109&_trkparms=aid%3D333008%26algo%3DRIC.MBE%26ao%3D1%26asc%3D34003%26meid%3D5859c2a66f8e4f3fa684c7882b547695%26pid%3D100010%26rk%3D2%26rkt%3D13%26sd%3D251191397304
and, of course, the second ones are WAY cheaper. I may be able to negotiate with the first guy, though.
You can buy brand new stainless repops of the bottle caps for $30-35/each from a variety of sources.....unless you specifically want the painted ones.
As for the second set, they are for something newer and probably not the size to fit your wheels. Note: the repops do not come with painted letters.
that's some good taping! Thanks. I think I'll attempt the same thing.
Get some really good tape and fresh razor blades and you'll do fine. Actually, an X-acto knife would probably be easier on the curves but I didn't have one. Another challenge is to do a light sanding of the letters once you get them masked off. If I remember correctly, I attached some 220 grit to a slim flat screw driver and carefully scuffed the flat part of the letters so the paint would have something to bond to.
This is the paint I used but you could also get paint used for pinstriping online if you prefer. I chose this color because I wanted to match the red on my "twinibeam" badges, but obviously, you can choose any color you want.
