Help please
Old Oct 22, 2015 | 09:30 PM
Aputchio19's Avatar
Aputchio19
Originally Posted by DND58
I'm not sure what you're saying here. did you get a "Check engine light", yes or no? Can you retrieve codes with a scan tool or reader?
I'm sure dying when opening the hood was coincidence.
Low fuel pressure would be more noticeable under acceleration, but also great place to check.
It wanted to die and than when I opened the hood it started to act normal. When I'm trying to retrieve that code the truck shut down. If I shut the truck off the codes won't stay so I won't be able to read them
Old Oct 22, 2015 | 09:33 PM
Aputchio19's Avatar
Aputchio19
But it will stall and than it will start back up and run for about ten minutes before acting up again
Old Oct 22, 2015 | 09:37 PM
Action4478's Avatar
Action4478
Get it scanned ( with a good scanner ), the codes will be there .
Old Oct 23, 2015 | 09:48 AM
madpogue's Avatar
madpogue
^^^^^ +1; generic OBD-II scanner will stall the engine when you attempt to obtain diagnostic codes. You need a device that communicates with the non-standard OBS PSD protocols.
Old Oct 24, 2015 | 09:05 AM
helifixer's Avatar
helifixer
Not yet I haven't the person I just bought it off of last week said the truck never ran when he got it put that sensor in and it ran the sensor is only 2 mo this old could it go bad already
a friend of mine had Ford install new CPS, as he was leaving dealer it failed. less than 500 feet of driving on new ford cps.
yes they can be bad within a few months but not the norm.
Dr. Johnson
Aug 29, 2014 06:09 AM
timmb
Dec 9, 2013 04:54 PM
lhud
13
Nov 24, 2012 04:57 PM
badassf250
28
Jan 29, 2011 10:43 PM
accobra1963
Oct 6, 2008 10:10 PM
