ignition switch question
Old Oct 21, 2015 | 07:41 PM
chrislynn5's Avatar
chrislynn5
I have the shop manual for my truck, 1948 Ford F-6. But I can't find the breakdown of which post, other than coil, goes to power and then ground?
It's a three position switch (middle allows key to come out).
I'm attempting to start my truck and need to make sure the switch has power I assume (I'm not hooking up the gauge cluster, etc.).
And which position from center is start?
Thanx!
Old Oct 22, 2015 | 07:13 PM
chrislynn5's Avatar
chrislynn5
ok, I traced through the shop manual and connected power to the switch and the engine. I wanted to avoid the gauge cluster but ended up going through it because it was needed This truck was converted to 12v and I'm finishing that out. I'm seeing 12v at the ignition coil, I assume that is ok. The truck turns over, I think it's not getting gas. I replaced the plugs and the coil wires (NOS).
rowdyreckless2012
Apr 9, 2013 06:53 AM
granny_rocket
Apr 16, 2012 12:14 PM
randylay
Electrical Systems/Wiring
Jan 31, 2006 05:35 PM
youngAZfordguy
16
Aug 12, 2004 10:27 AM
dada
Aug 10, 2003 08:08 PM
