Sponsored by: Real Truck
Climate Settings w/OEM Remote Starter?
Old Oct 21, 2015 | 12:22 PM
bignast1's Avatar
bignast1
Hello again. I recently purchased this remote starter and I installed it and had a local dealer program/cut the key.
11 thru 16 F250 F350 F450 F550 Genuine Ford Remote Starter Kit Plug N Play | eBay
I have an XLT without the message center. Do i have the manual temperature setting for when the remote starter is used? It has not worked either way as far as i can tell but it has also been very mild temps in illinois at 55-65 in the morning.
If i do have it, is it a setting i must engage somehow? I looked in the manual but could not seem to find anything.
Thanks for any help in advance
Old Oct 21, 2015 | 12:53 PM
droldsmorland's Avatar
droldsmorland
For the standard dash all you should need to do is leave the settings where you want them and the next time the truck is turned on it should resume with that setting unless Im miss understanding the question. I believe the same applies for the dual zone dash. Your owners manual will describe the optional HVAC controls for comparison with visuals.
Old Oct 21, 2015 | 01:14 PM
bignast1's Avatar
bignast1
I thought these trucks had a setting where if it is cold outside it will turn on the heat and if it is warm it will turn on the air?
Old Oct 21, 2015 | 01:15 PM
bignast1's Avatar
bignast1
But im wondering if that is for the lariat and above trim levels and/or message center equipped trucks.
Old Oct 21, 2015 | 01:40 PM
bignast1's Avatar
bignast1
Sorry, the productivity screen is the correct terminology.
Old Oct 21, 2015 | 02:03 PM
wrvond's Avatar
wrvond
According to my manual -
for hot conditions, the A/C will run at max
for cold conditions, the heater will run at max in floor/defrost mode and the electrical defrosters will be on too.
For mild conditions, the A/C will be on, the heat will be on, or the system will be off completely based on the last key cycle.
Sounds to me like, if you run the A/C then turn the key off, then use the remote start, the A/C should come on max.
Old Oct 21, 2015 | 02:31 PM
bignast1's Avatar
bignast1
ok-thanks! I was hoping its just because its not cold enough/hot enough to come on by itself.
Old Oct 22, 2015 | 05:24 AM
seville009's Avatar
seville009
In cold weather, it seems to wait until the engine is warm enough so that it's not blowing cold air. I leave mine set on defrost at 80 on high blower, but it won't actually do that until the truck has run for maybe five minutes or so
djargyle
Dec 7, 2010 08:38 PM
brooknbrown
2004 - 2008 F150
May 14, 2004 07:24 AM
amp17757
1983 - 2012 Ranger & B-Series
Oct 22, 2002 11:36 AM
