Shifting issue
Old Oct 20, 2015 | 08:17 PM
1738509's Avatar
1738509
Smile Shifting issue
My 1967 F100 will not shift through any of the gears unless you manually do it in the engine compartment. Any suggestions on what the issue may be and whatnI should troubleshoot for?
Old Oct 20, 2015 | 08:59 PM
HIO Silver's Avatar
HIO Silver
Auto trans, or manual on the column as in "three on the tree"?
First, lubrication is your friend... it's the least means.
Second, check for wear, worn, or misaligned parts. Chock the wheels, set the brake, and have a helper cycle through the actions.
Third.... the party is on with a shift column/linkage rebuild.
Old Oct 21, 2015 | 11:28 AM
72Truckin's Avatar
72Truckin
Was it shifting normally before?
And what changes happened prior (any modifications or parts changes?) to the no shift condition?
tumblindice
Nov 5, 2018 10:47 PM
john jamieson
Jul 4, 2015 02:27 PM
davbell22602
Jan 23, 2012 04:04 AM
KSRedsoxFan
Jul 14, 2010 07:13 PM
bigmike09
Sep 26, 2003 01:11 PM
