3 Spd. Column/Automatic Transmission Shift Levers
Old Jan 21, 2012 | 06:17 PM
davbell22602's Avatar
davbell22602
Will a 67 3 speed column shift lever fit/work on a 70 automatic column? They look the same to me.
1967 F100
Old Jan 23, 2012 | 04:04 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
They may look the same, but looks can be deceiving.
The A/T & M/T shift levers look the same when installed in the shift collar, but you cannot see the end of these levers where they attach to the shift tubes.
Once you remove and compare them, you'll discover they aren't the same. Neither are the shift collars and shift tubes: A/T is specific to A/T, M/T is specific to M/T.
66_in_ky
May 6, 2010 09:25 PM
sd59f100
13
Apr 1, 2010 02:25 PM
manning
May 16, 2002 09:12 PM
