led dash lights?
Old Oct 18, 2015 | 05:13 PM
Gary E's Avatar
Gary E
led dash lights?
I am getting ready to rebuild my cluster. can I get led bulbs? and if so will they work with the dimmer?
Old Oct 19, 2015 | 02:11 PM
ADOR's Avatar
ADOR
I am doing that right now. I was going to get the bulbs but decided since I wiring everything new to go with something a little different than the conversion bulbs.
Last post on this page is the pictures of what I did.
https://www.ford-trucks.com/forums/1...1-build-6.html
If you get the replacement style LED bulbs it will plug in just like the old bulb, but you will most likely have problems with the dimmer switch in your truck. You would need a special switch to dim them wired into the circuit.
This is one reason I swapped to colored LED's in my cluster build. The green I have will still be bright, but it won't be as bad as a bright white light shining right at you while going down the road.
Old Oct 19, 2015 | 02:30 PM
Gary E's Avatar
Gary E
I like your dome light panel I want some serious light out of the dome light. that looks like the ticket.
I did some more research and I guess technically you need an led dimmer but some say they still dim with the switch just a little I bought some led bulbs we will see how it works.
Old Oct 19, 2015 | 07:34 PM
ADOR's Avatar
ADOR
All I can say is it's dark out so I gave the LED dash lights and LED dome light a try. IT'S BRIGHT. Very bright. These pictures were taken at dark with out a flash.
20151019_113134 by Safjist Nipnog, on Flickr
20151019_113144 by Safjist Nipnog, on Flickr
20151019_184601 by Safjist Nipnog, on Flickr
20151019_184553 by Safjist Nipnog, on Flickr
20151019_190544 by Safjist Nipnog, on Flickr
20151019_190553 by Safjist Nipnog, on Flickr
All did to "mod" the original dome light housing for it to fit was take the guts out of the original bulb holder. Then I took a pair of pliers to turn the holder where the slits in the side was side to side in the dome housing. Then I put the lower part of the LED panel into the light housing. It held it still. If you were to drill the bottom out and take the whole bulb holder out you could fit a larger panel in there.
20151019_095438 by Safjist Nipnog, on Flickr
The way I did it you could always put the regular guts back into it later with out damaging it.
This panel comes with three different plug in ends, but all of them are wrong. So I just cut the end of the wires off of one of the adapters and wired it in direct.
This is who I got mine from, don't remember how long it took to come in but it's under 4 bucks shipped.
http://www.ebay.com/itm/361295094315?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Later on I was planning on some lights under the dash pointed down, I don't think I am going to need them now.
I had no reflective material left in my housing is why I wanted them all pointing forward and didn't use a bulb style LED like I did in my taillights. They make some round LED 12v Panels but they are a lot smaller and only have 9 LED's on them. The one I used has 24 LED's in it.
Old Oct 20, 2015 | 02:42 PM
Gary E's Avatar
Gary E
thats cool if they did not fit could you trim off a LED or two without messing up the rest?
I bought one, too slick and cheap My interior is all black it will need some light
Old Oct 20, 2015 | 10:01 PM
ADOR's Avatar
ADOR
It depends on how the board is made if you can do that. I didn't have the need too so I didn't look. That is the exact one I used so it should fit.
Old Oct 20, 2015 | 11:32 PM
Bluey Zedoff's Avatar
Bluey Zedoff
Curious to see how it comes out! My gauge lights are pretty dim. (it matches my IQ)
They are autometer gauges and I am using red inserts for the dash, but they are pretty dull, so I would think the LED's would be much better. Only thing is, LED's are very bright, very sharp light. That might get annoying after a while?
Old Oct 21, 2015 | 11:03 AM
Gary E's Avatar
Gary E
I wired up my dome light setup yesterday with the door switches its all complete except for the light and the bezel. the housing and lens are on backorder at mid fifty. Mine is the rectangular one so it probably won't fit without trimming or something.
Old Oct 22, 2015 | 12:39 AM
smallello's Avatar
smallello
Are we there yet?
I changed my dash to LED. It's a huge difference. See this thread:
https://www.ford-trucks.com/forums/1...my-gauges.html
And this one:
https://www.ford-trucks.com/forums/1...questions.html
Old Oct 22, 2015 | 11:57 AM
Gary E's Avatar
Gary E
smallello, thats exactly what I want to do to my dash cluster, thanks for the link.
Luke76
87
Nov 1, 2021 08:10 PM
TheRedlines
23
Jan 7, 2017 11:50 AM
kalebc2
26
Oct 15, 2016 10:09 PM
rechinca
Sep 17, 2016 12:06 PM
cookkd
Aerostar
16
Jan 28, 2008 03:08 AM
