Sponsored by: Real Truck
Correct Positive Battery Cable?
Old Oct 18, 2015 | 12:55 PM
luv2offroad2's Avatar
luv2offroad2
I'm really struggling to find the correct positive battery cable for my 2000 F250 Super Duty with v10 engine. Everything either doesn't have the connection to the solenoid or has an extra post connector that I have no clue where it would attach to.
Can someone tell me where I can find the correct cable? A part # maybe? If the one with the extra post connector on it is the correct one, where is that extra connector attaching to?
Old Oct 18, 2015 | 01:07 PM
seville009's Avatar
seville009
Not sure, but can't you get one made eith the connectors you need?
Old Oct 19, 2015 | 04:29 PM
luv2offroad2
I had some custom made but they are not right. I've contacted the guy and he came back with some specifications for me. (see below) I'm not knowledgeable about electrical stuff at all so don't know if these are correct. Any help?
battery to starter: 1/0, 63" with 3/8HD-90 (battery connection on starter)
add 6 ga 30" with 5/16 (start relay)
relay to starter
10 ga 72" with 5/16 (relay) and 1/4 (start signal on starter)
Old Oct 19, 2015 | 04:53 PM
seville009's Avatar
seville009
relay to starter
I'm not knowledgable about it either. We have battery stores around here; if you have something like that where you live, I'd go there and see if they can figure it out.
Old Oct 20, 2015 | 01:34 PM
Raymond's Avatar
Raymond
Veteran: Navy
The part you are looking for is MOTORCRAFT WC95679.
Old Oct 20, 2015 | 02:08 PM
jpr38057's Avatar
jpr38057
That part # shows to be for a 5.4. The Ford part # for the 10 cyl is YC3Z 14300-GA with a Motorcraft # of WC95597-B.
Old Oct 22, 2015 | 04:37 PM
Raymond's Avatar
Raymond
Veteran: Navy
I just got mine in the mail and it includes not only the main power cable from the battery bt the ground wire as well.
Etdesign
1983 - 2012 Ranger & B-Series
Jan 28, 2013 09:02 AM
LARIAT 85
Sep 24, 2011 03:04 PM
DUPPY
Oct 27, 2009 03:57 PM
blackpheniox
Bronco II
Aug 9, 2003 07:41 PM
frankster123
Electrical Systems/Wiring
Jun 8, 2003 06:54 PM
