General Automotive Discussion
Replacing Ignition Control Module?
Old Oct 17, 2015 | 07:01 PM
NICKSAN's Avatar
NICKSAN
94 E150, 5.8
Is there anything I need to do before replacing it?
Is it just a matter of:
Disconnect battery
Unhook connector
Unbolt module
Install new one?
I dont have to set the engine to TDC or something?
and should I set the timeing again after I replace it?
Hayne manual has nothing about installing it and Ive searched with no luck.
Thanks
Old Oct 17, 2015 | 10:48 PM
ford2go's Avatar
ford2go
You should check in the forum section for your truck for more specifics, but from what I remember.
Make sure that you get the heat transfer grease -- should come with the new one. Should also have instructions on where to apply it.
Also, make sure that you get the right module -- I know that there are gray and black ones, and I think that they're different.
Bolt heads are 7.5 mm (I think)-- oddball size ( might actually be 5/16). Requires a thin wall socket. On my I6, one bolt was the ground.
But, it's all electronic, so you don't have to do anything with the timing.
Good Luck,
hj
Old Oct 18, 2015 | 09:22 PM
Ford_Six's Avatar
Ford_Six
It seems most Haynes manual writer's heads would exploded at the thought of a TFI module or anything much more complex than a battery change.
If you don't have thinwall 1/4" drive sockets, I highly recommend getting the Ford TFI module tool. It should be Lisle number 64650, Napa usually has them on one of the spinner racks. Otherwise it's a 7/32" or 5.5mm socket.
jgrohs54
Jan 21, 2016 10:43 AM
cjben
Aug 12, 2008 11:31 AM
NJbronco138
1978 - 1996 Big Bronco
May 11, 2003 10:34 AM
spohl
Sep 11, 2002 09:32 PM
GammaDriver
Jul 8, 2002 08:51 PM
