Sponsored by: Real Truck
What else should I do while I'm flushing?
Old Oct 17, 2015 | 06:27 PM
noober0x's Avatar
noober0x
Replaced air filter
Going to flush coolant
Remove and rinse radiator
Replace cracked coolant overflow tank
Replace thermostat (203*!) and thermostat housing (yeah, old one is WASTED.)
Replace upper (and probably lower) radiator hoses. The top one made a cracking sound when I squeezed it. No telling what the bottom one is like...
What else should I do while I got the engine bay popped open and the truck front end raised?
This is on my new2me truck so I'm just going blind replacing pretty much everything. Fuel filter will be next once I figure out if I have a capped or capless filter.
Old Oct 17, 2015 | 09:01 PM
PineyMountainRacing's Avatar
PineyMountainRacing
Year, mileage and engine?
2 or 4WD?
If it's 4WD and diesel:
Both diffs
Tranny fluid
Transfer case
Check radiator hoses
Check the hose that fills the overflow from the bottom
S-belt
Flush brake fluid
That should keep you busy tomorrow afternoon!
Old Oct 17, 2015 | 10:29 PM
bobv60's Avatar
bobv60
I usually stay there and make sure it doesn't back up. Have the plunger ready just in case. Oh, don't forget to zip up
Old Oct 18, 2015 | 06:24 AM
Poncho450's Avatar
Poncho450
Going to a 203º thermostat and replacing the housing sounds to me like a 7.3 diesel job. If so, I followed the instructions in this link with excellent results. It's even got some of the part numbers for items you named listed.
Coolant changing instructions... - Diesel Forum - TheDieselStop.com
Old Oct 18, 2015 | 07:47 AM
redford's Avatar
redford
FTE Leadership Emeritus
Check your heater hoses also.
LIGOOMBA
Sep 10, 2014 05:44 PM
Million Mile Man
2004 - 2008 F150
Feb 27, 2011 12:37 PM
mhamric
1997 - 2003 F150
Feb 4, 2008 01:20 PM
allanhilliard
22
Nov 25, 2003 09:33 AM
GregR
Oct 11, 2000 12:33 AM
